need help i am using spoon lsd with amoil ful syntetic 75w90 there is noise
Old Feb 3, 2005 | 10:05 AM
Corinthians's Avatar
Default need help i am using spoon lsd with amoil ful syntetic 75w90 there is noise
need help i am using spoon lsd with amoil ful syntetic 75w90 there is noise what should i do does kazz realy take off the noise or other recogment kazz is pretty expensive any body can helpme what oil is good i did the research.
Old Feb 3, 2005 | 10:07 AM
Jon D's Avatar
Default Re: need help i am using spoon lsd with amoil ful syntetic 75w90 there is noise (Corinthians)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corinthians &raquo;</TD></TR><TR><TD CLASS="quote"> i did the research.</TD></TR></TABLE>
Rob will be with you momentarily if you didn't
Old Feb 3, 2005 | 10:11 AM
Bbasso's Avatar
Default Re: need help i am using spoon lsd with amoil ful syntetic 75w90 there is noise (Jon D)
Nope, I took the day off
Old Feb 3, 2005 | 10:21 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corinthians &raquo;</TD></TR><TR><TD CLASS="quote">need help i am using spoon lsd with amoil ful syntetic 75w90 there is noise what should i do does kazz realy take off the noise or other recogment kazz is pretty expensive any body can helpme what oil is good i did the research.</TD></TR></TABLE>
Your spelling and grammar is teh suck! Is english your first language?
If the Spoon LSD is a clutch-pack style, you need to either add a friction modifier to the Amsoil --or use a gearbox oil with a friction modifier in it already, such as Redline MT-90.
Modified by Mugen Mike at 1:34 PM 2/3/2005
Old Feb 3, 2005 | 10:29 AM
Project X's Avatar
Search GM Syncromesh in the archives...
Old Feb 3, 2005 | 10:41 AM
JeffS's Avatar
aclutchpackdifferentialisstillgoingtomakenoiserega rdlessofwhatoilyouuseobviouslythoughyou shouldbeusingsomethingwithafrictionmodifierinit
BTW, capitalization, punctuation and proper grammer will get you more helpful replies.
Old Feb 3, 2005 | 10:53 AM
Default Re: need help i am using spoon lsd with amoil ful syntetic 75w90 there is noise (JeffS)
any brand that sell the modifier? will kazz oil help
Old Feb 3, 2005 | 12:15 PM
Mugen Mike's Avatar
Redline sells it. Would you like me to go to the store and pick it up for you too?
Old Feb 3, 2005 | 01:20 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: need help i am using spoon lsd with amoil ful syntetic 75w90 there is noise (Mugen Mike)
First off, its 75w90
You need 80w90 GL5 oil
preferably KAAZ oil or ATS oil which is what I use in my sr20det 2 way s13 lsd
Did you break it in right?
If it is a stage two, noise on cornering is normal, its just the nature of the lsd
make sure you broke it in right driving in a number 8 with clutch stepped on while turning
MugenHonda's Avatar
Default Re: need help i am using spoon lsd with amoil ful syntetic 75w90 there is noise (MugenHonda)
If I am not mistaken, kaaz or ats makes the spoon lsd
Old Feb 3, 2005 | 06:43 PM
so kazz will eliminate the sound right how if i add friction modifier like tuffoil in the gear oil does it help
Old Feb 4, 2005 | 04:31 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">noise on cornering is normal, its just the nature of the lsd</TD></TR></TABLE>
Old Feb 4, 2005 | 04:59 AM
.RJ's Avatar
.RJ
Default Re: need help i am using spoon lsd with amoil ful syntetic 75w90 there is noise (Project X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project X &raquo;</TD></TR><TR><TD CLASS="quote">
Search GM Syncromesh in the archives...</TD></TR></TABLE>
wtf are you talking about?
This thread is "t3h suck"
Old Feb 4, 2005 | 05:56 AM
Mugen Mike's Avatar
Default Re: need help i am using spoon lsd with amoil ful syntetic 75w90 there is noise (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">This thread is "t3h suck"</TD></TR></TABLE>
x2
Old Feb 4, 2005 | 09:36 AM
but mine is really bad sound like the drive shaft is tearing a part and the whole car jerk
Old Feb 4, 2005 | 09:40 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corinthians &raquo;</TD></TR><TR><TD CLASS="quote">but mine is really bad sound like the drive shaft is tearing a part and the whole car jerk</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">If the Spoon LSD is a clutch-pack style, you need to either add a friction modifier to the Amsoil --or use a gearbox oil with a friction modifier in it already, such as Redline MT-90.</TD></TR></TABLE>
Old Feb 4, 2005 | 10:05 AM
Mugen Mike's Avatar
What aren't you understanding here????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffS &raquo;</TD></TR><TR><TD CLASS="quote">aclutchpackdifferentialisstillgoingtomakenoiserega rdlessofwhatoilyouuseobviouslythoughyou shouldbeusingsomethingwithafrictionmodifierinit</TD></TR></TABLE>
Old Feb 5, 2005 | 07:42 AM
i already add some tufoil or the friction modifier i guess i have to use kazz then beside that any suggestion?
Old Feb 7, 2005 | 08:07 AM
check this out https://honda-tech.com/zerothread?id=1141191
Old Feb 7, 2005 | 08:10 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corinthians &raquo;</TD></TR><TR><TD CLASS="quote">all u need to do is get engine treament oil ya engine treatment oilnot friction modifier cause good engine treat ment oil will bring gear box temperature down since there is no radiator or cooler to cool down the temperature.One of the brand are tufoil or tuffoil which is in the guiness book world of record </TD></TR></TABLE>
Old Feb 7, 2005 | 08:14 AM
MattD@Stoptech's Avatar
my head esplode no
Old Feb 7, 2005 | 09:23 AM
Default Re: need help i am using spoon lsd with amoil ful syntetic 75w90 there is noise (El Pollo Diablo)
mine is very quiet now not too slipery though
CTR_B
15
Feb 8, 2008 05:06 PM
B20inDCinLBC
Apr 28, 2006 09:51 PM
garyc17
Feb 24, 2006 09:18 AM
loclowd
Oct 13, 2005 05:41 PM
kibbi
Nov 3, 2003 03:05 PM
