vtec solinoid
search. I read a post at one time that a early NSX gasket works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexdog69 »</TD></TR><TR><TD CLASS="quote">The JDM B16A/PR3 EF SiR solenoid is dfiferent. I can't comment on the XSi B16A, however.
P08 is not the right gasket.
15825-P08-005 compatible solenoid:
Left to right: EF B16A/PR3 solenoid, 15825-PR3-005, 15825-P08-005
Notice the PR3 has a sharp bend at the top and the P08 has a smooth curve. The P08 is also much thicker.
If you look at the different DOHC solenoids (PR3 vs P08 style) you will see the differences in the gaskets CLEARLY reflected in the machining of the solenoid face.
The areas circled in red will usually tear when you put a P08 gasket in a PR3 solenoid.
I tried the P08. Twice. It was wrong. It could have worked if I rednecked it a bit more. It was a sloppy install at best.
I did a lot of searches. Other people had the same problem. They tried every USDM equivalent they could think of.
YMMV
For me, the 91 NSX (15825-PR3-005) gasket was the correct part.</TD></TR></TABLE>
YMMV
beat me to it. I was gonna say that. But get this. i went to Ball acura down near me and the dude told me the 91 nsx vtec selenoid was a two part deal. That's right two vtec selenoids.....is that right? But yeah that's the right part number...also you could try a del sol vtec (94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EFHatch »</TD></TR><TR><TD CLASS="quote">91 nsx part number: 15825-pr3-005
Yup, my buddy and I just verified this on his 1st gen b16a.
</TD></TR></TABLE>Yup, my buddy and I just verified this on his 1st gen b16a.
Yobee
Dec 9, 2012 08:16 AM
Jason Nucom
Nov 27, 2012 06:23 PM
Jason Nucom
Nov 26, 2012 05:23 AM
coot_er
Aug 15, 2005 12:36 AM
madman13lm
Feb 21, 2003 06:13 AM
