ITB's and all that jazz!
Am thinking of getting some ITB's.. but have no clue about them!
My current setup is i/e/h, s2s1 cams, hondata s100 ecu. No head work and stock compression.
Will i get good low end power & torque from that setup using ITB's and once tuned will the power be smooth across the rpm range?
Modified by caranjo at 10:56 AM 2/3/2005
My current setup is i/e/h, s2s1 cams, hondata s100 ecu. No head work and stock compression. Will i get good low end power & torque from that setup using ITB's and once tuned will the power be smooth across the rpm range?
b 1 6 a 2
Oct 10, 2007 02:33 PM
X2BOARD
16
Dec 20, 2004 05:23 AM
