Crank pulley, harmonic dampener question
Old Feb 3, 2005 | 01:14 AM
Tad's Avatar
Tad
Default Crank pulley, harmonic dampener question
OK I have a d15b vtec motor,
and say I want to use a CRV crank pulley on it.
Will the CRV pulley still serve its function as a harmonic dampener properly?
even though it's on a different engine?
Also, say I had a machine shop remove the extra pulley rings(ac/ps etc)
for weight savings, would this mess with the dampening function at all?
reason for this is it will up the boost on my jrsc.
thanks in advance.
Old Feb 3, 2005 | 04:29 AM
NJIN BUILDR's Avatar
Default Re: Crank pulley, harmonic dampener question (Tad)
As long as it is two piece with a rubber isolator in between it is a damper and not just a hub.Machining the pulleys off will not change its dampening properties significantly.You should have it balanced after you machine the pulleys off.Any shop that does engine balancing can do the pulley only for around $25.
Glenn
Old Feb 3, 2005 | 11:41 AM
Tad's Avatar
Tad
Default Re: Crank pulley, harmonic dampener question (NJIN BUILDR)
cool! thats good news
Old Feb 3, 2005 | 12:53 PM
Tad's Avatar
Tad
oh, just to clarify,
it doesnt matter that the damper was made for a crv but i'm using it on my d15b?
it'll still dampen just as good?
Old Feb 3, 2005 | 01:06 PM
Default Re: (Tad)
Yes.It will work fine.If I remember the vx d-series had a solid pulley,but that was designed to run about 2500 rpm.I'm sure the crv is a two piece will the rubber isolator.
Glenn
Old Feb 3, 2005 | 01:09 PM
Tad's Avatar
Tad
Default Re: (NJIN BUILDR)
cool!
i just ordered one off ebay.
I think i'm going to take it and have it lightened as much as possible(balanced too of course).
heres a pic
hondamark35
Apr 26, 2011 08:10 PM
dipsy
Northwest (Sales)
Feb 15, 2011 05:44 AM
thehatchninja
Jul 13, 2008 10:04 PM
supercharged18
Feb 20, 2005 04:56 AM
david90
Aug 15, 2003 01:15 PM
