noisy walbro pump, is it normal?
just fitted a walbro pump after having the oem one seize up. there is a constant hum from it when running, is that normal?
just unsure of whether i've installed it correctly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S »</TD></TR><TR><TD CLASS="quote">No worries
Mine is noisy as crap. You get used to it</TD></TR></TABLE>
same here, everyone around here can deff. tell if you have the WAL-PRO. thats how i tell it's time to hit the gas station lol
My experience....: I had a walbro Fuel pump that used to hum like a fridge and it got worse/louder as the tank got lower on fuel.. I found out that i had the WRONG pump 'model' for my car..
i just put the correct model walbro pump and i hear absoluttelly nothing, just like stock..
so.. make sure u r using the correct pump for your car.
255 LPH...... mine is loud and when I get to 1/4 tank and less...I lose power because my fuel pressure drops a few pounds....also I have a 30 amp relay powering it cause it burnt the contacts on my stock plug...should of got a smaller pump if I would've known... I have an 88 hatch so I have to drop the tank to change it..lucky EG/integ owners
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries »</TD></TR><TR><TD CLASS="quote">it buzzes like a fridge.</TD></TR></TABLE>
radiohead.
radiohead.
