spoon throttle body????
Old Feb 2, 2005 | 10:17 PM
AllmotaB18EH2's Avatar
Default spoon throttle body????
is spoon throttle body really worth it???like money wise and performance wise???
would it be basically the same sending my type r one to maxbore to get a 70mm bore??? and a lot cheaper...but if the spoon will flow more better then i guess $500 wouldnt hurt....but i really dont want to cough up that much if i dont have to
or everyones opinion is welcome
Old Feb 2, 2005 | 10:25 PM
UncleD's Avatar
Default Re: spoon throttle body???? (H.A.R.T B18C5EG6)
I would hafta say no......
http://www.importreview.com/re...8.jpg
Old Feb 3, 2005 | 12:55 AM
Icey112's Avatar
just go max bore.
Old Feb 3, 2005 | 02:02 AM
siR cr-x's Avatar
Default Re: (Icey112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 &raquo;</TD></TR><TR><TD CLASS="quote">just go max bore.</TD></TR></TABLE>
you will save alot more going this way
Old Feb 3, 2005 | 02:22 AM
chris_m's Avatar
* B A N N E D *
Default Re: (siR cr-x)
the spoon is just a taper bore on a stock itr plate
Old Feb 3, 2005 | 05:15 AM
1quickhatch's Avatar
Why would you go 70MM on an all motor setup?? Am I missing something here?? Ain't that a little too big??
Old Feb 3, 2005 | 09:43 AM
Default Re: spoon throttle body???? (1quickhatch)
85mm gsr block
golden eagle sleeves
crower rods
12:5:1 comp endyn pistons
ls crank
type r alaniz head
skunk valve train
rev valves
skunk 2 stg 2 cams
skun intake mani
440 injecters
aem fuel rail and reg
Old Feb 3, 2005 | 10:07 PM
bump
Old Feb 4, 2005 | 04:12 AM
b19coupe's Avatar
Default Re: (alld16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alld16a &raquo;</TD></TR><TR><TD CLASS="quote">the spoon is just a taper bore on a stock itr plate</TD></TR></TABLE>
The Spoon TB is not worth the money. Get an Erick's or RPM TB. Less money, more power.
Old Feb 4, 2005 | 03:28 PM
chris_m's Avatar
* B A N N E D *
Default Re: (b19coupe)
that motor needs atleast a 68 mm throttle body plate size. rpm or dhracing billet I have them in stock
Old Feb 4, 2005 | 03:36 PM
JoeB18R's Avatar
if you buy spoon you will just be spending a lot of extra money on the spoon name. go with a modified stock TB or something like BBK. Stick with 63-65mm.
Old Feb 5, 2005 | 10:44 AM
H.A.R.T B18C1EG6's Avatar
Default Re: (JoeB18R)
just go to maxbore
Old Feb 15, 2005 | 11:56 PM
Bunger's Avatar
Default Re: spoon throttle body???? (H.A.R.T B18C5EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T B18C5EH2 &raquo;</TD></TR><TR><TD CLASS="quote">is spoon throttle body really worth it???</TD></TR></TABLE>
Not at all, The Spoon TB is just an ITR TB that has a taper bore to 70mm, the throttle plate is the same. I guess if you were going to buy a stock ITR TB from the dealer, then the Spoon one would be better, since it also comes with a TPS (factory set) and MAP sensor.
HondaPH22
Honda S2000
Dec 14, 2006 02:26 PM
Spaceballsthelunchbox
Oct 14, 2005 08:30 PM
57one
Oct 16, 2002 01:22 PM
"SPOON EG"
Jul 26, 2002 11:25 AM
IntegraT
Dec 18, 2001 09:42 AM
