Gauge cluster HELP
I have a 94 CX hatch and I cant get the black part of my dash off to put in a new gauge cluster. There is 2 screws on the top of the gauge cluster dah on the underneath side of it located right above the speedometer and then i had to lift up my hazard light button and unscrew the 3rd screw behind that. But the black dash still wont come off so I can pop the gauge cluster out. Is there a 4th screw or is it just 3- the 2 underneat on top and the 3rd under the hazard light button?
The first time popping the black bezel is tough. Use a flathead and pry the driverside of the bezel, then pry the center vent part. It should come out.
Okay thanks for the help but i need to know how many screws do I remove from the black bezel.?????????????????????
There are 2 on top underneath near the speedometer and 1 underneath the hazard button (which you have to lift up)
However it still seems tight so is there a 4TH SCREW OR 5TH????????
please sum1 help me!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDeEM-ike »</TD></TR><TR><TD CLASS="quote">Okay thanks for the help but i need to know how many screws do I remove from the black bezel.?????????????????????
Just those three. The rest are clips. Take your time, the plastic is easy to break.
Blazin Civic
Jun 21, 2004 10:24 AM
MikeTheVike
Dec 10, 2001 09:08 PM
