brown top zc
Old Feb 2, 2005 | 08:42 PM
kevo2k6's Avatar
Default brown top zc
where can i buy a brown top zc motor online?
Old Feb 2, 2005 | 10:40 PM
ServiceAdvisor's Avatar
Why online? Those motors cam in 88-89 Acura Integras. Hit up just about any junkyard and I'm sure you can find 3-4 in perfect condition. They only bolt into 84-87 CRX/CIVIC Chassis.
Http://www.redpepperracing.com for more info on Brown Top ZCs. - Darrell
Old Feb 3, 2005 | 08:53 AM
jlicrx's Avatar
Default Re: (DOHCZCCRXSi)
brown top ZCs are JDM ZC engines with around 130hp - the ZC engine code stamped in the block is on the back of the block just above the starter - they are not USDM Integra D16A1 112hp engines which had brown valve cover and came in 86-87 integras with vacuum advance distributor - 88-89 USDM integras, 118hp, had black valve cover and electronic ignition advance - JDM brown top ZCs are getting harder to find - best bet is to search for "used japanese engines" and try the various importers
superbeastcrx
Jan 23, 2006 11:35 AM
cbstd
May 28, 2004 06:08 PM
shinobes
Oct 2, 2002 08:56 AM
BigDaddyRich
Aug 13, 2002 06:10 PM
ZCRX
Mar 7, 2002 08:35 AM
