type r camshafts
Old Feb 2, 2005 | 08:37 PM
allmtrdc4's Avatar
Default type r camshafts
ok guy i need to know how you can tell the difference in a typr r cam shaft and a gsr i got a gsr engine out of a junk yard and i think the cams in it might be type r's but not sure but i need to know thanks guys if any body has a picture explaining that would be great
Old Feb 2, 2005 | 08:45 PM
-=Zeqs=-'s Avatar
Default Re: type r camshafts (allmtrdc4)
Look for the groove on there.
Old Feb 3, 2005 | 02:44 AM
allmtrdc4's Avatar
Default Re: type r camshafts (-=Zeqs=-)
so the grooves will only be on the small part on the very end because mine have one groove on the small part on the very end
Old Feb 3, 2005 | 12:33 PM
clint g's Avatar
That is the best answer I have ever seen!
Old Feb 3, 2005 | 05:44 PM
-=Zeqs=-'s Avatar
Default Re: type r camshafts (clint g)
Thank Katman for that info. It came straight from ff-squad. Glad to have the opportunity to relay the info though
Old Feb 3, 2005 | 05:45 PM
Miracle_X_Bar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -=Zeqs=- &raquo;</TD></TR><TR><TD CLASS="quote">Thank Katman for that info. It came straight from ff-squad. Glad to have the opportunity to relay the info though </TD></TR></TABLE>
Katman is gay, but he does help with info like this!!
Old Feb 3, 2005 | 06:08 PM
JesseCRX's Avatar
Ok, I have a question.
I have OEM CTR cams and a firt gen B16 out of a CRX SiR. If I swap the stock cams for the newer CTR cams is a valvetrain upgrade necessary??
Old Feb 3, 2005 | 06:11 PM
99 TYPE R's Avatar
I would recomend a valvetrain, If you tend to use your stock rev limit you dont have to upgrade your springs and retainers.For future use i would.
Old Feb 3, 2005 | 06:53 PM
JesseCRX's Avatar
Default Re: (99 TYPE R)
Well, I'd like to get the most out of the CTR cams as possible....does this mean that to harness their full potential I'd have to rev past the stock rev limiter?
Right now I have the entire engine out of the car and I have a choice of keeping the stock cams and leaving it all alone or adding the CTR cams only and keeping the stock valvetrain. If I have to take off the head to do a valvetrain upgrade then that's going to open up a whole new can of worms which will include new gaskets, new hardware and I may as well port and polish the head while it's off right?
I guess I am wanting to know are the CTR cams even worth adding to a stock B16 head without having to modify anything??
Old Feb 3, 2005 | 07:45 PM
-=Zeqs=-'s Avatar
Default Re: type r camshafts (Miracle_X_Bar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miracle_X_Bar &raquo;</TD></TR><TR><TD CLASS="quote">
Katman is gay, but he does help with info like this!! </TD></TR></TABLE>
What has he done to make him "gay"?
He's never been anything but helpful in the posts I observe from him. He was completely cool with me when I bought a ECU jumper from him.
Old Feb 3, 2005 | 07:56 PM
-=Zeqs=-'s Avatar
Default Re: (JesseCRX)
If you plan on adding R cams, they do offer improvements, even if you keep the stock valvetrain and ECU. Consider adding adjustable cam gears though and dyno tuning it so that you can get the cams dialed in. Without upgrading the valvetrain to handle a higher redline, modifying the fuel tuning curve, porting the head slightly, the cams are still good for a few ponies throughout the powerband. Depending upon your external mods, possibly 5 whp horses more. Those cams tend to enjoy breathing at higher RPM's though.
pouponu
14
Apr 1, 2008 10:47 AM
EJ1 Type Slow
Jun 6, 2007 05:21 PM
stock99si
Apr 23, 2007 07:52 PM
honda_hatch
Mar 8, 2006 08:45 PM
CHIA
Dec 22, 2004 04:48 PM
