mini me HELP! d15b8 / Z6 ? would it work?
i have a 92 civic cx(d15b8) w/ the 8 valve head, im wondering if i can slap a z6 head on there (mini me) or will i have clearence problems? i know some old 8 valve engines came w/ 16 valve reliefs....if ya know pass on the wizdom
if they have the slots on both sides like 16 valve pistons yes.
if not, then you are gonna have to replace alot of stuff if you try it.
slots are there for a reason which is to allow the pistons and valves to have clearence
what year is ur d15b8. mine was a 93.
u dont need to change out the piston. the cx block has a 16 valve relief. ur sets. just drop in the head , take out the oil jet. if u need help just pm me or watever, cuz i did a mini me setup on my cx block, with z6 head, z6 IM with tb, chipped p05 ecu to p08 specs with the 1 wire o2 sensor.
great setup, u can keep up with b16 delsol /coupe and ls
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">if they have the slots on both sides like 16 valve pistons yes.
slots are there for a reason which is to allow the pistons and valves to have clearence </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic »</TD></TR><TR><TD CLASS="quote">what year is ur d15b8. mine was a 93.
great setup, u can keep up with b16 delsol /coupe and ls</TD></TR></TABLE>
where can i read how to chip my p05 ecu you a 16valve non-vtec 1wire 02 sensor?
dcwoodard
Jul 23, 2006 03:14 PM
Slow89HB
Sep 30, 2003 06:13 PM
