Car Will Not Start | Electrical Problem | Details Inside
Old Feb 2, 2005 | 04:56 PM
nevin's Avatar
Default Car Will Not Start | Electrical Problem | Details Inside
I just finished swaping a b18a into a 90 dx that I bought with a blown motor. It had allready been converted to mpfi and was running a si motor.
I can start the car by having the key in the run position and touching a hot wire to the terminal on the starter.
The problem is that the car will not crank or anything when the key is turned to the crank position. All I hear is a click under the dash.
I tested all the fuses and they are good. I put a test light to the wire going to the starter and when I turn the key to the crank postion it dosen't light.
The motor is grounded in 3 places, I have the harness grounded on the thermostat, and the battery is in the trunk grounded to the spare tire thing.
Can someone explain to me how to troubleshoot this?
I don't know if this is related but the clock and radio worked before the swap and now they don't.
Modified by nevin at 3:09 PM 2/3/2005
Old Feb 2, 2005 | 05:25 PM
Super Chicken's Avatar
Default Re: Car Will Not Start | Electrical Problem | Details Inside (nevin)
Sounds like the clutch /neutral safety switch is not set up correctly. Was the car an automatic before? And have you checked the connection and adjustment on the clutch switch?
Old Feb 3, 2005 | 12:07 PM
nevin's Avatar
Default Re: Car Will Not Start | Electrical Problem | Details Inside (Super Chicken)
I don't belive it was ever an auto.
I ran a +12v wire from the fusebox to a $2 button from walmart to the starter selenoid to start my car now.
Super ghetto but I can drive my car around now untill I figure this out.
Old Feb 7, 2005 | 12:43 PM
sleevedgsr's Avatar
Nevin you should have made that quackey mexican you bought the REX from fix it before you bought it! I talked to him at AI he told me he sold it to you and he asked me if you had fixed the starter problem yet!
Old Feb 7, 2005 | 12:53 PM
PrettyLude's Avatar
sounds like your ignition switch is shot, check and see if they have a fuse for the starter signal also
Old Feb 8, 2005 | 10:29 AM
nevin's Avatar
Default Re: Car Will Not Start | Electrical Problem | Details Inside (1quickDC2)
everything on the cluster stopped working yesterday... havent had time to **** with it yet. Turn signals stopped working also. I start the car with a push button lol. I love electrical problems
Old Feb 12, 2005 | 12:13 AM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
ignition switch
silez
May 1, 2014 03:55 AM
Coopa B18c5
Mar 24, 2013 11:58 AM
clikoyl
Nov 5, 2009 01:01 PM
lsvtec2000
Mar 5, 2008 04:12 PM
ghost_ryder35
Sep 7, 2005 05:53 PM
