jun cams
Old Feb 2, 2005 | 03:45 PM
civicswap's Avatar
Default jun cams
I plan on running a ls vtec with oversized ctr pistons and a gsr head are jun cams really worth the money or should i just go with something cheaper? If not what do u recommend?
Modified by civicswap at 6:38 PM 2/2/2005
Old Feb 2, 2005 | 04:02 PM
2k.civic.si's Avatar
Default Re: jun cams (civicswap)
go with something cheaper...buddy club 4's seem to be a really good cam even when compared to some of the newer cams that have come out since their release...like tbones bc4 vs sk2 pro1 cams.....
Old Feb 2, 2005 | 04:07 PM
civicswap's Avatar
Default Re: jun cams (2k.civic.si)
what do you think about the skunk2 stage 3?
Old Feb 2, 2005 | 04:29 PM
topspeed86's Avatar
JUN Cams are really good I have 2's and 3's make great power
What Compression is your setup
Old Feb 2, 2005 | 04:37 PM
civicswap's Avatar
Default Re: jun cams (topspeed86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topspeed86 &raquo;</TD></TR><TR><TD CLASS="quote">JUN Cams are really good I have 2's and 3's make great power
What Compression is your setup</TD></TR></TABLE>
probably around 13:1
Old Feb 2, 2005 | 04:49 PM
topspeed86's Avatar
Don't Go Cheap on Cams you will spend more $$$$ in the long run to get the right ones
Old Feb 2, 2005 | 05:18 PM
rjay8604's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topspeed86 &raquo;</TD></TR><TR><TD CLASS="quote">Don't Go Cheap on Cams you will spend more $$$$ in the long run to get the right ones</TD></TR></TABLE> I would say go with what suits your setup best, I think all the cams out there are quality as far as strength goes, but its little other factors that lead to cam breakage. With 13:1, you'll be looking at some pretty aggressive cams to suit that compression, i'm no cam master, but there's enough dyno runs and setups and info on here to where you can make a good educated decision, theres definitely no "perfect" science involved with cam choice, but a good guess and estimate is feasible. good luck finding something.
Old Feb 2, 2005 | 05:35 PM
HONDA_TYPE_R's Avatar
Default Re: jun cams (rjay8604)
https://honda-tech.com/zerothread?id=717928 R/S ratio explained (long)
https://honda-tech.com/zerothread?id=1088178 PCT piston comp. ratio
Read these threads...very useful info concerning your setup. You'll also find the exact compression ratio for your setup (barring any milling or thinner head gasket). You'll also find out what cams would be best suited for your setup concerning the R/S ratio and air flow of the cam.
sirwags
Jun 5, 2005 03:51 PM
FastAllmotorLsVtec
Jun 24, 2004 08:32 PM
GreenR
Jul 23, 2003 12:26 PM
mini-cRx
Jun 25, 2003 01:41 PM
NewbieFirstTimer
Jul 2, 2002 07:46 PM
