dust shield b16a swap
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">
from: http://crxpage.com/tech.htm</TD></TR></TABLE>
Damn, Phil is the man!
I bought custom axles so I did not have to remove them..
But on the last swap I did,I had to..
Use a hammer and flat chisel and some safety googles..
ps>Be careful ..
When I popped it out,It bounced off my forehead..
Sup Vap..
ps>Be careful ..
Sup Vap..
http://www.driveshaftshop.com/
I bought them on Ebay for $199.99 +$35.00 shipping [Jan. 2003]
sellers name was driveshaft1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">ps>Be careful ..
What I would gave to see that. Raxle also sells custom axles. I took my dust shields off but my axles would still not spin freely, but I came up with a good idea that has worked very well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ronin150 »</TD></TR><TR><TD CLASS="quote">What did you do so that they would spin freely. I'm trying to take the most convient way out. I checked out raxle.com. Are there any other ones out there.</TD></TR></TABLE>
Well I still suggest you try to remove the dust shield to see if it helps. But basically picture a big heavy duty washer ( and I'm talking big enough to slip over the end of an axle ) . Used it like that, this keeps the axle from pulling into the hub so much and causing it to get stuck.
