High RPM?????
Old Feb 2, 2005 | 01:35 PM
92_EGhatch's Avatar
Default High RPM?????
My Rpm is @ 1000, and i don't have a clue what's going on. I should be @ 500-700 around there. but every since i put the itr manifold on and take it back off and out the stock p30 delsol Vtec one on then it is reving and is @ high RPM.
Old Feb 2, 2005 | 04:03 PM
lohatch's Avatar
Default Re: High RPM????? (92_EGhatch)
you probably have a leak somewhere which is allowing the motor to get air from somewhere. this would cause it to idle higher than it should. did you use a new intake manifold gasket?
Old Feb 2, 2005 | 04:18 PM
rtmiami's Avatar
Default Re: High RPM????? (lohatch)
easy way to check a leak it to grap some Brake Cleaner (parts cleaner) and spray it around the intake mani gasket and throttle body gasket. If the idles waver, one of your gaskets are bad.
This is typical of a mani change (done it myself)
Good luck
Old Feb 3, 2005 | 05:47 AM
Flitch's Avatar
Default Re: High RPM????? (rtmiami)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtmiami &raquo;</TD></TR><TR><TD CLASS="quote">easy way to check a leak it to grap some Brake Cleaner (parts cleaner) and spray it around the intake mani gasket and throttle body gasket. If the idles waver, one of your gaskets are bad.
Good luck </TD></TR></TABLE>
Yea, I had a friend who had the same problem. This is what diagnosed it. Good luck.
Old Feb 4, 2005 | 04:15 PM
92_EGhatch's Avatar
Default Re: High RPM????? (Flitch)
Well i haven't try the brake Cleaner but i don't think it's the gasket. Because i just change it brand new. And it doesn't sound leak either.
Sep 20, 2010 01:50 PM
Hardedge
Dec 9, 2007 09:18 AM
NguyenDC2
Dec 8, 2007 09:53 PM
g2tegsown
May 7, 2007 06:09 AM
joecivic93
Jan 3, 2004 10:25 PM
