Air Intake 94 Accord -HELP
I just was about to install my new air intake in my 94 Accord EX, but the problem is that there are too many connections to the factory intake. There's the two vacuum hoses, and something (?) connected to the bottom of the tube. The new intake has ONE connection (i'm guessing for the hose leading to the valve cover). What do I do?
I would tell you to use a search but i didnt when i installed mine so here you go
OK the electronic looking connection on the bottom of the factory intake disconnect it and all the vacume line associated with that. This will leave you with the connector still attached to your car leave it unconnected and fold it back up somewhere or just let it hang.
On the passenger side by the headlight there was vacume hose remove the hose and youll want to cap this off
Then on the firewall there were 4 vacume lines that came together remove the top right hose but dont cap it off leave it open. and if you want you can make a filter for it outta like a small fuel filter or one of those 9mm valve cover breathers or you can be lazy and just leave it wide open.
Im developing some pictures today ill take some of my intake so you have visual reference. Shoud have them online in like 2 days cuz i dont have a scanner they have to be sent to me.
Well, my email server is down. So once it is back up, I can upload the pics.
hehe
sorry, im a computer geek
I believe what he means is: his email server is down -> he can't download pics -> he can't upload pics to his host server.
if p -> q.... q ->
if p -> q.... q ->
your email server is down, so you cant upload pics, eh?
Which hose is the one that you don't cap and can put on the 9mm filter on? And so basically there is only 1 hose that was capped, which is the one that is on the passenger side by the headlights (doesn't that hose, if you follow it run up all the way to like almost the very top center of the engine bay, and can you cap it from there?.)
[Modified by raceACCORDingly, 8:36 PM 1/20/2002]
He had some nice filenames... but, im lazy... here the directory the pics are in
http://pages.sssnet.com/mikey/tifagsr/
keep it real homies
keep it real homies
Henry Juliao
Jan 8, 2022 10:12 PM
