RPM GOING NUTS
When at idle my car rev's between 1k & 2k rpm and it seems like it's running hard or something what does this mean. It use to do this on cold starts and once the warmed up it would be ok, but now it does it non stop.
Thanks for the help
Thanks for the help
check your idle control valve-located on the throttle body, it may need to be cleaned. Also, there is a screw that controls the vacuum for you idle also on the thorttle body, it may have worked itself loose, try tightening it. My ZC engine did the same thing in a CRX. *Please feel free to correct me if i am wrong anyone* hope this helps!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist »</TD></TR><TR><TD CLASS="quote">Year? Model? Please move a little to the left. I can't see your car.</TD></TR></TABLE>(I think I'm gonna get a lot of mileage out of this quote...)
Usually the idle-air control valve (IACV) is bolted to the back of the intake manifold. Sometimes there's also a fast-idle-thermo-valve (FITV) bolted under the throttle body. Beginning sometime before '98, the FITV function was built into the IACV.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lxvteckilla »</TD></TR><TR><TD CLASS="quote">Could this have something to do with my cat being bad. </TD></TR></TABLE>
i dont think its the cat causing this. there.s post out there talk about it and show how you coud fix it. look for it.
dnbruut
Jan 12, 2007 02:38 AM
