rim size choice
Old Feb 2, 2005 | 09:45 AM
95vtecsrus's Avatar
Default rim size choice
i got a 95 accord 4dr ex....im in the process of lowering it 1 3/4 inches, what is the biggest size of rim i could get without any problems with rubbing?
Old Feb 2, 2005 | 09:51 AM
SOLO1racer's Avatar
Default Re: rim size choice (95vtecsrus)
You should get 16" Rota c8 racing bronze on 205/55/16 tires
Old Feb 2, 2005 | 01:24 PM
hondaracin24's Avatar
Really you can have almost any size rim and tire up to 17". 18" + are questionable and you usually have to do some type of modification with the fender....
Old Feb 2, 2005 | 02:45 PM
95vtecsrus's Avatar
Default Re: rim size choice (hondaracin24)
well, if i got 16's they wouldnt rub on anything? and wouldnt i have to calibrate my speedo or some **** like that
Old Feb 2, 2005 | 04:40 PM
h22accordvtec's Avatar
Even with 17's and 18's your speedo would be fine with the right tire size. I am running 16" precedeo's (you will never find them unless you look at a 12+ year old wheel catalog from Japan) with 205/50/16. This is the correct tire size but if you want a taller tire 55 series wouldnt hurt. If you want more grip you can go with 215/45 or 50 series. Again its up to you and your preference.
Old Feb 2, 2005 | 05:00 PM
95vtecsrus's Avatar
Default Re: rim size choice (h22accordvtec)
hmm, yeah, alright thanks for everyones input..also another question, not related to the subject though. i have 180xxx miles would it be a good idea to change the water pump now, because i dont think it has been done, i work at an auto parts store so i can get stuff reasonably cheap. I dont think it has been changed yet but the previous owners were mechanics, and they failed to tell me any history on the car..
Old Feb 2, 2005 | 05:02 PM
jakeiscool's Avatar
Banned
Just use 15s broseph. No need for more rotational mass.
Old Feb 2, 2005 | 05:41 PM
95vtecsrus's Avatar
also i kinda want a different steering wheel, i found some "hubs" on ebay will they work with airbag equipped vehicles? i mean i know i gotta take the airbag out (the sombitches dont work anyways)
Old Feb 2, 2005 | 11:15 PM
'00Accordster's Avatar
Dont listen to these fools son, you need to go wit some 20s, straight up!
Nbboy7
Apr 12, 2008 05:38 PM
yaryar
Jan 10, 2008 07:11 AM
BOTAN01
Nov 23, 2007 09:55 AM
HuskerHybrid
Aug 26, 2005 06:58 PM
GetawayInMoscow
Jul 10, 2002 05:53 PM
