NOOB question. Brake fluid and power steering fluid the same????
Just noticed my power steering fluid is on the lower level. At the moment, the only thing I have handy is Valvoline Syn Power brake fluid. Could I use that for the power steering fluid or should I just go out and buy regular power steering fluid? Thanks in advance.
yes. It's no.
edit: Oops, no. I thought you were talking about brake and clutch fluid. These 2 are the same.
Modified by DutchITR1689 at 6:19 PM 2/2/2005
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
Oh man that one hurt like hell....... Wheww~!
No do not use it, It's not the same.....
Takes Mike's advice....Go buy some Honda powersteering fluid....
Absolutely don't mix the two. Typically brake components use 'EPR' seals and o-rings, where as power steering system components use 'BUNA' seals and o-rings. Putting the wrong fluid in either system will surely destroy the seals and o-rings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint »</TD></TR><TR><TD CLASS="quote">Absolutely don't mix the two. Typically brake components use 'EPR' seals and o-rings, where as power steering system components use 'BUNA' seals and o-rings. Putting the wrong fluid in either system will surely destroy the seals and o-rings. </TD></TR></TABLE> Very Well Put....!
tgordenDELSOL
Oct 5, 2014 05:01 PM
tslam
May 22, 2012 07:45 AM
