Gear oil refill
Old Feb 1, 2005 | 11:50 PM
Reason01's Avatar
Default Gear oil refill
OK dumb question.....where and how do I drain the gear oil for the tranny? I bought some stuff by Redline and dont know where to put it. I wanted to do it before this weekend, so any help would be cool, pic would be nice too if anyone has some. The car is a 89 CRX DX 5speed ....thanks
Old Feb 2, 2005 | 12:00 AM
ServiceAdvisor's Avatar
Remove the intake/Battery tray/ and the starter. There's a wide/thin bolt beneath it. I believe its the metric equivalent to a 3/4" socket. And beneath the tranny there is a plug with a square hole, just pop your 3/8th" wrench onto it like it was a socket and start loosening. - Darrell
Old Feb 2, 2005 | 08:11 AM
Reason01's Avatar
Default Re: (DOHCZCCRXSi)
Cool thanks
Old Feb 2, 2005 | 08:18 AM
crxdonwon's Avatar
Default Re: (Reason01)
or get a long funnel. Pull the speedometer sensor out of the trans, and wa-la big *** hole, put long *** funnel into big *** hole and pore 1 9/10 quarts of yo' fluid into trany. Put speedometer sensor back. Then drive that Mo' Fo' all weekend long. Don't forget to stop and get some gas though. The bolt is a 10mm, pull it out. Take a srew driver and pop the sensor out. You don't have to take the cable off either. Have fun!!!!!
Old Feb 2, 2005 | 10:40 AM
Reason01's Avatar
Default Re: (civicdonwon)
I need a damn Haynes manual lol
Old Feb 2, 2005 | 11:39 AM
fourthgenhatchB17's Avatar
Are u actually putting in gear oil (i.e. 80W-90) or is it redlines light weight stuff?
Old Feb 2, 2005 | 12:25 PM
gray89si's Avatar
Default Re: Gear oil refill (Reason01)
1)park car in 1st gear and set parking brake
2)get floorjack and raise passenger side frontend high enough so you have room to work.
3)Remove passenger side wheel
4)MAKE SURE YOU LOOSEN THE TRANSMISSION FILL PLUG BEFORE LOOSENING THE DRAIN PLUG(itll be a large plug (I think its 19mm)right next to the upper control arm) THE REASON I SAY THIS IS BECAUSE THE FILL PLUG IS AT A VERY HARD ANGLE TO REACH AND IS VERY EASY TO ROUND THE HEAD!!!! (The drain plug is the 3/8 square plug in) If you dont do this youll end up draining your transmission and having no way to refill it until you get a new plug from honda,(and get your old one off)
5)Drain your old transmission fluid from the aforementioned 3/8 plug-in
6)get 2-3 feet of clear plastic hose to lead into the transmission
7)add transmission fluid into trasmission until fluid pours out of the hole, then put the plug back in
8)put wheel back on
9)lower car from floorjack
Old Feb 2, 2005 | 01:58 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Gear oil refill (gray89si)
The filler plug is a 17mm:
The black hole in the center is where the passenger side axle goes in..
Old Feb 2, 2005 | 02:59 PM
JapJunkie's Avatar
Default Re: Gear oil refill (88DXCRX)
...or if you want to stay clean you can remove your reverse light sensor and fill there, easy does it.
Old Feb 2, 2005 | 05:03 PM
SwissChEz82's Avatar
Default Re: Gear oil refill (JapJunkie)
You still have to check the level though.
Old Feb 2, 2005 | 05:12 PM
mr_valentino20032000's Avatar
Default Re: Gear oil refill (SwissChEz82)
hey does anyone have a pic of the reverse light thingy? my fill bolt the 17mm bolt is stripped and i need it to be running and drivable before i can get get another bolt
Old Feb 2, 2005 | 05:23 PM
88DXCRX's Avatar
Default Re: Gear oil refill (mr_valentino20032000)
Reverse switch is at the end of the blue line..
The green one is a vent hose which will probably work also but it is
kind of small..
Old Feb 2, 2005 | 05:26 PM
I would have to say filling thru the VSS hole is the easiest and fastest.
Old Feb 2, 2005 | 05:30 PM
damn...that is a small hole from what i remember. I think i might just get a small pipe wrench or something to losen and remove the fill bolt.
Old Feb 2, 2005 | 05:34 PM
88DXCRX's Avatar
Default Re: Gear oil refill (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">I would have to say filling thru the VSS hole is the easiest and fastest.</TD></TR></TABLE>
Here is a pic of that:
note:sensor must be removed first...
I have always used the filler plug but whatever works...
Old Feb 2, 2005 | 06:58 PM
Reason01's Avatar
My bad, I thought I had Redline. I bought this stuff, LUCAS High Performance/Heavy Duty 85/140 plus gear oil. I seen a "demo" gear set with this in action, It contains "climbing additives. Now is this the right stuff I need? is it good?
Old Feb 2, 2005 | 07:26 PM
xbB's Avatar
xbB
I use the reverse sensor
Old Feb 2, 2005 | 08:27 PM
BOSS-REX's Avatar
Fill the trans through the back up light sensor hole. It's the best and easyest way to do it. Be careful when you pull the wires off before you take the sensor out, then be careful when you wrench it out, its a knuckle buster. Its hard as hell to pore oil up in to the factory filler hole. Make sure you check the level of the oil through the factory filler hole. Its a messy job so put something on the ground to catch the oil that runs out. Have fun.
Old Feb 3, 2005 | 06:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reason01 &raquo;</TD></TR><TR><TD CLASS="quote">My bad, I thought I had Redline. I bought this stuff, LUCAS High Performance/Heavy Duty 85/140 plus gear oil. I seen a "demo" gear set with this in action, It contains "climbing additives. Now is this the right stuff I need? is it good?</TD></TR></TABLE>
Dont use it. 10W30 motor oil or Honda MTF. Light weight stuff is a must for Honda trannys.
Old Feb 3, 2005 | 06:58 PM
ijjz's Avatar
Syncromesh!
Btw, fill in the right location so you know when its full, as shown in the pic above.
Old Feb 3, 2005 | 07:07 PM
trustnoone7935's Avatar
Default Re: (ijjz)
sorry not trying to jack your thread,but is royal purple MTF any good?
Old Feb 3, 2005 | 08:46 PM
Reason01's Avatar
Default Re: (trustnoone7935)
What are a few good fluids to use? How about synthetics?
Old Feb 3, 2005 | 09:15 PM
.DOHCebag.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reason01 &raquo;</TD></TR><TR><TD CLASS="quote">What are a few good fluids to use? How about synthetics?</TD></TR></TABLE>
how about 10w30 or honda MTF fluid like suggested
Old Feb 3, 2005 | 10:45 PM
FalkenSiR's Avatar
Default Re: (recluse)
synchromesh did it for me
Old Feb 3, 2005 | 10:56 PM
EF9Si-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by recluse &raquo;</TD></TR><TR><TD CLASS="quote">
how about 10w30 or honda MTF fluid like suggested </TD></TR></TABLE>
Thats what honda recommends,and uses! I know, I serviced them for the last five years.
