info on converting to obd1?
Old Feb 1, 2005 | 05:14 PM
ALLMOTA92EG's Avatar
Default info on converting to obd1?
i have a 92 hatch and a 88-91 b16 motor that i can get for dirt cheap, so how would i convert the motor over to obd1 to use it? or can i use any old parts off my old motor to make it work?
Old Feb 1, 2005 | 07:26 PM
d.str0y's Avatar
you would need to use your d-series saturated injectors, your 4-wire o2 sensor, and you would need to buy an obd1 dohc vtec dizzy. additionally, you would need a p30 ecu or a chipped p28
Old Feb 16, 2005 | 07:54 PM
am i going to need obd1 injector clips?
Old Feb 16, 2005 | 09:31 PM
eda6's Avatar
Default Re: (onezexycrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthehardedgex &raquo;</TD></TR><TR><TD CLASS="quote">am i going to need obd1 injector clips?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthehardedgex &raquo;</TD></TR><TR><TD CLASS="quote">i have a 92 hatch</TD></TR></TABLE>
obd1 injector clips should already be on your engine harness
Old Feb 17, 2005 | 11:50 AM
Blown90hatcH's Avatar
You do not need to run the OBD1 injectors. If you want to run the OBD0 injectors, you will need to wire in a resistor box.
Old Mar 12, 2005 | 02:17 PM
NilsG's Avatar
Default Re: (Blown90hatcH)
Does an B16A1 dizzy work with OBD1 ECU ?
Or must I have an B16A2 dizzy ?
Old Mar 12, 2005 | 02:22 PM
ekb16's Avatar
there is ppl out there using a OBD2 dizzy wit their OBD1 setup and it works for them but there is also ppl out there running OBD1 dizzy wit their OBD1 setup and it works for them..but some say u CAN and some say u CANT...i did the OBD2 dizzy wit the OBD1 setup and my car wont run so i suggest u go wit OBD1 dizy and not OBD2.
Old Mar 12, 2005 | 04:12 PM
NilsG's Avatar
Default Re: (ekb16)
B16A1 is PreOBD, not OBD2.
Sleepy_Red_hatch
Mar 4, 2006 08:59 AM
91dxcrx
Jan 22, 2006 09:27 AM
Daily Interlude
10
Feb 1, 2005 05:01 PM
Gant
34
Jul 24, 2004 01:59 PM
aVstAr
Dec 26, 2003 07:41 PM
