Highest compression all motor (Gas)
Methanol will make better power after 15:1-15.5:1, simply from the ability to have full control over ignition advance from the fast burn.
Leaded race gas can support compression numbers in the 15's, but you will be sacraficing ignition timing. 15:1 is probably right where you want to be if you want to have full control over timing advance.
Lei Siew Long
17
Aug 17, 2004 04:01 PM
JsNA99si
Jun 16, 2004 02:51 PM
