what internals would you use?
I recently bought a d16z6 for my hatch and decided that i wanted do a rebuild. It is going to be a daily driver, well at least start out that way, but i don't want anything too crazy. I was wondering if i could get a few suggestions as far as pistons, rods and cams go.
Well in the future do you plan on boosting, spraying, or staying N/A. When you figure that out, then do some research on the best parts for your application.
Um, go with a 10 to 12:1 CR piston, some eagle/pauter/etc rods, and a Crower stage 2 or 3 cam! And build the valve train too!
Oh I give this answer cause I'm a retard and building a mild N/A d-series, but will probably end up boosting it anyways, so I'm leaving the CR low.
Honda_Fanatic
16
Nov 7, 2007 06:48 AM
lukerc45
Jul 29, 2007 08:45 PM
