Making sure I have this right
Old Feb 1, 2005 | 02:58 PM
SpoolnEG6's Avatar
Default Making sure I have this right
Ok I am about to order my toda header because it is at an extremely good price.
I just want to double check that i get all i need. I need a "JDM length" cat and the donut gaskets. I believe the cat is 12.75" long, correct me if i am wrong. Also if i need anything else feel free to chime in with it. I did a search and i just want to make sure i received the right info from my readings.
Edit: I am running a Buddy Club Pro spec exhaust on the car now.
Modified by SpoolnEG6 at 2:57 PM 2/2/2005
Old Feb 1, 2005 | 04:24 PM
Padawan's Avatar
Darth ModerVader
Default Re: Making sure I have this right (SpoolnEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnEG6 &raquo;</TD></TR><TR><TD CLASS="quote">Ok I am about to order my toda header because it is at an extremely good price.
I just want to double check that i get all i need. I need a "JDM length" cat and the donut gaskets. I believe the cat is 12.75" long, correct me if i am wrong. Also if i need anything else feel free to chime in with it. I did a search and i just want to make sure i received the right info from my readings.</TD></TR></TABLE>
The length of cat you need depends upon what car you're installing the header on (or more specifically, what exhaust system you're running). You only need one donut gasket, but you will also need a 3-bolt gasket for the joint between the cat and the B-pipe.
Old Feb 1, 2005 | 04:30 PM
Type-Rare#1248's Avatar
hey man, where are you getting it from?? and how much?
Old Feb 1, 2005 | 06:00 PM
chad's Avatar
Moderator
as was stated NOT HEADER dependent unless you get a GSR header...
i do have a used toda header for sale if anyone is interested
Old Feb 1, 2005 | 07:06 PM
totsie7944's Avatar
I am not sure about the cat. Why not just throw a test pipe in there instead. I have a carsound cat with my jdm 4-1 header and smsp exhaust and the cat is 16". I would like to know how long the test pipe will have to be if i get a toda header actually. I am assumming its longer than the JDM 4-1 that i hvae.
Old Feb 1, 2005 | 07:35 PM
SpoolnEG6's Avatar
Ok i will be running it on a usdm type r. as far as the price im getting for under 700 new. i was just wondering also if i can utilize the stock cat for the time being.
Old Feb 1, 2005 | 07:45 PM
Bbasso's Avatar
no stock cat, different size.
must get yourself a cat made up to match or a test pipe.
SwoleDaddy
30
Jul 24, 2013 09:40 AM
98itr0448
Sep 1, 2004 05:28 PM
PeteBest
Aug 15, 2004 10:32 PM
dc4drewH
May 5, 2003 05:16 PM
BUSAFREAK
Jul 18, 2001 07:54 AM
