Exhaust manifolds the same?? Need to know for TURBO!!!
I am planning on swapping a d16a1 into my 85 CRX Dx (yes I am aware I will be doing the Carb-FI swap) and I might make a home made turbo kit. I am aware that 88-00 Civic's have the same exhaust pattern (at least I believe so)..
my question is the 86-89 Integra (mainly the 86-87) do they have the same exhaust pattern as the other d-series? If not what would/could be the easiest route for a junkyard turbo? What manifold would i use? I was hoping to through on a HF (CRX/CIVIC) or just get a cheap manifold from ebay.
Help please.
Does it make sense?
Help please.
Does it make sense?
well the brown and black top along with the 1g (and 2g) ZC's are all d-series but they are DOHC. They came in 86-89 Integras. They are pretty much a direct swap into the 84-87 CRX/Civics.
So thats where I am unsure and need to know any help on the manifolds?
Any d series header will work on the ZC or d16a1. I had a 92 civic ex header on my old ZC so it does work.
However the exhaust ports are slightly shifted but that can be taken care of with a dremel or air grinder. Just take the exhaust manifold gasket and trace the ports onto the manifold and grind away.
ninjarico
Apr 20, 2005 07:41 PM
maxxdout
May 19, 2003 09:43 PM
