my ignition key is stuck help
like the title says the key is stuckin the ignition. When I turn it off in only goes to the 1(or acc). The key is brand new so I am thinking that it is the key but how do I get it out? I thank you all in advance for your help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracin24 »</TD></TR><TR><TD CLASS="quote">If it was made at home depot im sure it would be a different story. Because Honda could blame the cause on them and make you pay for it....</TD></TR></TABLE>
true
true
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alotawatts »</TD></TR><TR><TD CLASS="quote">Automatic trans ?</TD></TR></TABLE>
Are you sure its in park?
yep, got that problem before, i started the car again, shifted to D4 or whichever gear, shift it back to park really hard, dont break it haha, key came out easily... or u can try taking out all the key chains n stuff, use a vise grip, grip it to the key, and turn using the vise grip. dont take my words for it..
Try to "wiggle" in P and N, and try to remove the key at the same time. If your car is about 80k+ miles, your shift-gear switch probably just about to go out. I got the same problem before, wiggling method work for a while but eventually had to replace the switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sillyboi »</TD></TR><TR><TD CLASS="quote"> shift it back to park really hard, dont break it haha, key came out easily... or u can try taking out all the key chains n stuff, use a vise grip, grip it to the key, and turn using the vise grip. dont take my words for it..
Bad advise. All you have to do is gently bump the lever forward after it is in Park. You will here a click. My 97 EX does this. I'm guessing cleaning the switch contacts is the fix.
We still don't even know if it's an automatic do we ? How 'bout it SNYDERMAN5 ?
</TD></TR></TABLE>Bad advise. All you have to do is gently bump the lever forward after it is in Park. You will here a click. My 97 EX does this. I'm guessing cleaning the switch contacts is the fix.
Are you sure you're steering wheel isn't locked? Try to move the wheel hard to one side or the other while you turn the key? This can be a surprise if you're new to the car.
