failed inspection
Old Feb 1, 2005 | 10:15 AM
MPALUGHI's Avatar
Default failed inspection
I have a 91 stock ef and just failed the stupid friggin emmisions test. Does anyone know any avenues I can go to pass the stupid thing. It sucks too they charge you even if you fail!! I am going to list the readings that the test gave.
Pollutants High speed test@ 25mph low speed test @ 15mph
standard my reading standard my reading
HC(PPM) 153 269 159 283
CO(%) 0.86 1.00 0.89 0.84
NOx(ppm) 1123 2481 1242 2827
PLEASE HELP IF YOU CAN I ONLY HAVE TO WEEKS LEFT TO GET IT INSPECTED AGAIN BEFORE THOSE ***** CHARGE ME MONEY AGAIN. THANK YOU.....
Old Feb 1, 2005 | 10:22 AM
Burlyirishdude's Avatar
Default Re: failed inspection (MPALUGHI)
find a place that does, "pass or free retake"
1st- it's going to save you a lot of headache if you track down your p[orblem and fix it now.
2- Paying someone to "pass" you is kinda risky....well i'm from So. Cali so we can get popped for even mentioning, "under the table" but if you know the right people yes it's possible.
3- a CEL will fail you everytime....check your ecu for codes...
good luck
Old Feb 1, 2005 | 10:28 AM
4drEF's Avatar
Keyboard Humorist
Old Feb 1, 2005 | 07:20 PM
89hbcivicguy's Avatar
Default Re: failed inspection (4drEF)
try changin your O2 sensor and you air filter
Old Feb 1, 2005 | 07:25 PM
shocker's Avatar
replace or check cat to
Old Feb 1, 2005 | 07:26 PM
crxvtecturbo's Avatar
* B A N N E D *
Default Re: failed inspection (89hbcivicguy)
will they exempt you if your car is to low if so slam that bitch down to the ground so they waive you
ehLAaay
Jan 4, 2011 07:56 PM
piggydog
May 16, 2006 07:32 PM
JDMGSRCRX
Honda Motorcycles
21
Aug 19, 2004 07:29 PM
SIK IN DA HED
Jul 9, 2004 01:30 PM
crxtreme27
Jun 12, 2003 04:15 PM
