What was your best time?
Old Jan 14, 2002 | 07:41 PM
J30A2ccord's Avatar
Default What was your best time?
Whats your best 1/4 E.T? My best E.T. is 16.34@85.7MPH down here at Honolulu Raceway Park.
Old Jan 14, 2002 | 07:48 PM
Conechaser's Avatar
Default Re: What was your best time? (J30A2ccord)
Best 1/8 9.8 @ 72 2.11x 60'
Best 1/4 16.1 @ 86 (i believe that was my trap speed) 2.29x 60'
Old Jan 14, 2002 | 08:22 PM
CD8's Avatar
CD8
Default Re: What was your best time? (94Accord)
16.1@85.
what mods to you guys have. list em.
im stock except for custome intake, weight reduction, and no p/s.
i just got my suspension on, hopefully it will help my launch but im not sure.
[edit] oh ya, and i gots a 96 coupe ex 5spd.
[Modified by exaccord, 5:23 AM 1/15/2002]
Old Jan 14, 2002 | 09:21 PM
Conechaser's Avatar
Default Re: What was your best time? (exaccord)
Just an AEM CAI and susp. full interior
Old Jan 15, 2002 | 03:11 AM
urbanlegend21's Avatar
New User
1 min 14 seconds- Summit Point Jefferson cicuit
1 min 45 seconds- Summit Point Main Course
3 min 38 seconds- Virginia International Raceway Full Course
Old Jan 15, 2002 | 04:34 AM
Gennady's Avatar
New User
Default Re: What was your best time? (urbanlegend21)
I like that!
Old Jan 15, 2002 | 05:30 AM
LDYKLLA's Avatar
New User
16.03 @ 86(ish) in an I4 6th gen coupe with only intake and exhaust...
Waiting for the spring to try out new setup.. added header and dyno-tuned VAFC... 145whp and 145lb/ft
[Modified by LDY KLLA, 2:34 PM 1/15/2002]
Old Jan 15, 2002 | 05:35 AM
SOHCArchangel's Avatar
Default Re: What was your best time? (LDY KLLA)
15.7 at battle in june 2000
alleged 14.6 @ 96 per gtech meter last night, i dont think this thing is accurate at all
Old Jan 15, 2002 | 07:29 AM
LDYKLLA's Avatar
New User
Default Re: What was your best time? (SOHCkordVTEC)
I'm curious about your mods, Misa... care to enlighten us??
Old Jan 15, 2002 | 07:42 AM
sure, here:
Engine:
Custom 3” wrapped CAI 3 bends total
HKS super mega flow filter
H23 Throttle body port matched to manifold plenum
Manifold deburred, polished and port matched to head
RC 240 cc Injectors
Kamikaze headers port matched to head
2.5" headder colector on back into 5 zigen fireball
lightened, balanced, stress-relieved stock flywheel
clutch masters stage III clutch
Front polyurethane motor mount insert
STR cam gear
AEM power steering pulley
Underdrive crank pulley
MSD 6al ignition box
MSD blaster SS ignition coil
Magnecore 9mm ignition leads
Torquemaster spark plugs
MSD distributor cap
Solid rear hasport motor mount
Suspension:
Apex progressive rate spring 4.4 kg/mm front 4.0 kg/mm rear
OBX front strut tower brace
OBX rear strut tower brace
OBX rear lower tie bar
Progress front camber kit with delrin bushings
Tociko blue shocks
16x7” Rota N1R’s
205/50/16 Falken VR ziex’s
Brakes:
Front: brembo blanks upgrade from 5th gen v6 4 door and matching calipers
Hawk hp plus for street, carbotech panther plus for track
Russel stainless steel braided brake line
ATE super blue fluid
Weight reduction:
Front and rear re-inforcements swisscheesed
Battery re-located to trunk
Entire removal of all a/c components
Corbeau forza drivers seat
Rear seat metal backing removed
Trunk gutted
Debadged rear and front
Cruise control removed
Glove box removed
Accessories:
Greddy shift ****
Sparco alum pedals
B&M short shift adapter
Custom made polyurethane shifter bushings
15% tint
NER sticker on driverside quarter window
JDM clear corners with yellow bulbs
Stock lenses (!)
Twin beam light weight projector headlights
Sound:
Pioneer P800R head unit (recently stolen )
Infinity kappa 6x9’s
CW 6.5”’s
Aero:
Removed rear bumper under molding
State of tune:
Ignition timing advanced fully
Rev limit: 6500rpm
Fast idle valve removed and plugged
Oil Filter Magnet
Cam advanced 1 degree TDC
Old Jan 15, 2002 | 07:45 AM
ArchAngel Sabastian's Avatar
New User
.... damn
Old Jan 15, 2002 | 08:05 AM
Default Re: What was your best time? (Sabastian)
.... damn
oh im not done yet, hondata, 440's, and some mild head work is coming ^_^
Old Jan 15, 2002 | 08:26 AM
New User
Overall the glovebox removal is my personal Favorite
sounds like nice work misa did you do your own port matching?
oh yeah 16.3 consecutively on all 3 runs i ever did.
that was with full interior and underhood intake. only plus i was still semi learning my clutch and crap. Hopefully when i break out the beat this spring we can break in 15 teritory.
Mods done over winter.
Real CAI
H22 TB With port match Throttle body
Kamikaze 4-1 Header (with removed reducer as soon as misa shows me how.)
bosch +4 plugs
Magnacor Wires
OBX free flow Cat.
Crush Bent Cat Back With OBX R Dual Chamber Muffler
Mandrel Bent Cat Back 5zgien Fireball muffler. (on order)
Tunned VAFC
Kyb AGX Shocks/Struts (On Order)
OBX Coilovers
Front Rear Upper Strut Bars
Rear Lower Tie Bar
Rear Sway Bar
Ingals Camber Correction Kit
Brembo Front and back rotors (front V6 Converstion)
EBC Green Pads
Back Seat Removed
Trunk Gutted
Floor Mats Removed
Driver and pass Tenzo r Rally Type Reclining Sport Seats
30% tint
some stock ex 7spokes
that i will powder coated white prolly if i ever find some for sale.
Oh and a rear solid mount in the works
[Modified by Sabastian, 9:36 AM 1/15/2002]
[Modified by Sabastian, 9:41 AM 1/15/2002]
Old Jan 15, 2002 | 08:27 AM
yes i did
Old Jan 15, 2002 | 08:39 AM
New User
yes i did
what ecu are you gonna swap to for the hondata?
i got the TB and my instructor was supposed too... instruct me on how to do so like a month ago but hes such a chevy lovin slacker... oh well its free tech school
Old Jan 15, 2002 | 08:51 AM
New User
Civic Si/Ex P28 OBD I, sorry i looked into the Hondata too
Old Jan 15, 2002 | 10:12 AM
yup, well ill take pics for you sabastian, when i get to daves house to in stall my spoon sports ss clutch hose
Old Jan 15, 2002 | 11:36 AM
smokin rubber's Avatar
I know i asked before but will all lude tb fit, and what about the plenum and manifold. times and mods below
Old Jan 15, 2002 | 11:39 AM
Default Re: What was your best time? (smokin rubber)
yes it will fit, you have to portmatchit to your stock plenum or it wont work , and no the lude manifold wont fit
Old Jan 15, 2002 | 01:33 PM
LoudAccord's Avatar
14.846 @ 93mph with full interior, 17inch rims, before my dyno tune and AEM fuel stuff. The track had no grip either.
Cant wait for spring I will have my light weight rims, ACT clutch, CM flywheel and Quaife LSD. I hope to run 13s all motor with some other stuff.
Old Jan 15, 2002 | 03:33 PM
Mike P.'s Avatar
25 Year Member
Default Re: What was your best time? (LoudAccord)
14.87 @ 92
Old Jan 15, 2002 | 04:31 PM
Default Re: What was your best time? (Mike P.)
mike this is accords only take your torqueless wonder elsewhere
Old Jan 15, 2002 | 04:38 PM
LoudAccord's Avatar
what does Mike P. drive?
Old Jan 15, 2002 | 05:12 PM
mike has an si, that he road races and drives the living **** out of , hardcore **** too drive around on falken azenis competition rubber on the street
Old Jan 15, 2002 | 07:13 PM
Conechaser's Avatar
How much larger is the H23 TB over the F22?
