With clutch replacement, is flywheel replacement necessary/advised
Old Jan 31, 2005 | 08:06 PM
BigC-ivic's Avatar
Default With clutch replacement, is flywheel replacement necessary/advised
OK, so I'm going to put in an Exedy stage 1 clutch and was looking at getting a flywheel....
its just that they are a lot of cash
can I just resurface a flywheel with 200,000 kms on it? Is that a terrible idea?
I thought about getting a less expensive type-r flywheel but those I have talked to said I'd hardly notice a difference
Old Jan 31, 2005 | 08:14 PM
notstock93's Avatar
Default Re: With clutch replacement, is flywheel replacement necessary/advised (BigC-ivic)
Just resurface unless something it visibly askew. The flywheel is not a real "wear item"
Used light flywheels are pretty cheap, and most aftermarket ones use a replacable friction surface, too.
You can also safely take about 3-4 lbs off the stock b-series flywheel for around 50 bucks at a machine shop.
Old Jan 31, 2005 | 08:32 PM
M!lly's Avatar
resurface it if your on a budget.
but if your not get a lightened one if you already know your gonna get one further down the line
Old Jan 31, 2005 | 08:40 PM
PrettyLude's Avatar
get a fidanza off ebay, they're pretty affordable
Old Jan 31, 2005 | 08:48 PM
BigC-ivic's Avatar
everything seems cheap, until you try to ship it to Canada, then UPS or FedEx rape you with an extra $100 for bringing it across the border
I wanted to not spend much cash on my car this summer, but so far I have a new head, new cams on the way, I need to buy new valve springs and retainers, new cam gears, I just bought a CF lip.... its getting expensive
Old Feb 1, 2005 | 07:12 AM
PrettyLude's Avatar
welcome to the club
maxogsr
Transmission & Drivetrain
Mar 13, 2013 11:03 AM
vgsr
Apr 27, 2005 02:46 PM
slooogsr
May 1, 2004 06:59 AM
Dirty GS-R
Feb 5, 2002 05:08 AM
