pre 92 intake manifold on a 92 eg
Old Jan 31, 2005 | 07:37 PM
nicehatchy's Avatar
Default pre 92 intake manifold on a 92 eg
ok i bought my car with a jdm d15b swap. but the idiot that did the swap left the stock cx intake and exhaust manifolds. i already swaped a si exhaust manifold with the full piping. now my friend gave me an intake manifold from a 89 si. it has all the same vacum lines and sensors as mine except for that it does not have a map sensor on top of the throttle bodie like mine does. i know that the map sensor works off vacum. is the sensor somewhere else or can i just run a vacum line to the map sensor or is it garbage and can't be used on my car?
Old Jan 31, 2005 | 07:52 PM
nicehatchy's Avatar
Default Re: pre 92 intake manifold on a 92 eg (nicehatchy)
anyone?
Old Feb 1, 2005 | 08:54 AM
RyanD03's Avatar
bump
Old Feb 1, 2005 | 09:16 AM
DJ_SaNdOz's Avatar
The 91 Si used a MAP that was mounted on the firewall. You may be able to get an EG+ throttle body that uses a TB mounted MAP....
BTW teh D15B7 (EG) uses the same IM
93redcb7
12
Jun 15, 2016 02:22 AM
civicegb18
May 18, 2010 08:46 PM
B16A CRX
Jul 9, 2007 06:14 PM
flipldls
Jul 8, 2007 06:25 PM
88 rex
Aug 16, 2005 06:49 PM
