Cusco Zero 2's from EG to DC2?
i know that eg springs will fit my DC2's. my question is, i recently bought a set of Cusco Zero 2's Coilovers that were on an EG civic. when i install them, will my DC2 sit lower with the eg combo as opposed to me having the proper DC2 coilovers? i need to know if i should install them onto my DC, or, slam them onto my EF civic? any help would be appreciated.
It will most likely sit lower do to the weight difference of the EG and DC. Should be able to just turn em up ont he sleeves. Depending on the diameter of the spring, you can order just the springs from Eibach or VIS. Friend ordered some from VIS couple years back and paid 25 or 50 bucks per spring. Hope this helps good luck.
Sir_JDM
Jun 14, 2005 08:29 PM
