What's a good Suspensions set for Daily Driving, and cornering? And Intake to use? $1000
Old Jan 31, 2005 | 05:12 PM
XyKo
Guest
Posts: n/a
Default What's a good Suspensions set for Daily Driving, and cornering? And Intake to use? $1000
Well, I was testing out my db8 stock suspension on a winding road, and the car don't seems to want to be push into corners. I love this road alot, and it's a back road with golf courses. Alot of turns and sometimes, there's ricers with their hook up cars wanting to race me. But like always, I lay back and let them do whatever.
So, what's a good set of suspensions to start? I don't want a bumpy ride, just comfort, but can performs well. Also, any good suggestions for an intake?
I'm pretty new to this, and finally set my goal turn this car into daily driver/sleeper.
And is there any good brake pads/rotors? Would like to go brembo, but don't know which ones. Drill holes or just plain?
Thanks for the input, and I'm looking into learning more about these vtecs.
FOr suspensions, would spend around $1000.
Old Jan 31, 2005 | 05:25 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: What's a good Suspensions set for Daily Driving, and cornering? And Intake to use? $1000 (XyKo)
probally one of the best suspension setups for under a grand would be the Koni Sport Kit. It comes with the koni yellow shocks, and koni springs. It is a relatively firm ride, perfect for the cratered surface of Chicago roads, and stiff enough that the car doesn't roll as much. As for intake, probally one of the best would be the comptech icebox. Check out this link for the sus though : https://honda-tech.com/zerothread?id=1121444
You can see the differance between the before and after for the GSR.
Old Jan 31, 2005 | 05:26 PM
marsbike's Avatar
Default Re: What's a good Suspensions set for Daily Driving, and cornering? And Intake to use? $1000 (marsbi
almost forgot: The Sport Kit is around 750
Old Jan 31, 2005 | 05:29 PM
kevin85193's Avatar
I to was looking into supsension. I'm going to go with Koni Yellows w/ Ground Control Coilovers
Old Jan 31, 2005 | 05:30 PM
marsbike's Avatar
you guys might want to check out the suspension forum. It has some awsome info, even shock dynos and whatnot. Good stuff.
panchlow
Jul 29, 2010 04:49 PM
hC_858
Suspension & Brakes
19
Dec 2, 2008 08:20 PM
CaponeGotti
Jun 17, 2005 02:20 PM
maryzknight
Jan 23, 2003 05:04 AM
Tru Dynamix
Jan 22, 2003 03:37 PM
