rod question??????
Old Jan 31, 2005 | 05:11 PM
toooslow's Avatar
Default rod question??????
What is used to determine a rods strength or durability, is it rpm or horsepower.
I want to run an ls crank, ls rods and itr pistons in my gsr block. Thinking of going with Skunk stage 2's so i will be revving to like 9 grand. obviously i wont be putting more than 200 horsepower to the wheels. I heard of b16 rods being able to handle this but can ls rods?
Old Jan 31, 2005 | 06:37 PM
mmuller's Avatar
Mad Scientist
Default Re: rod question?????? (toooslow)
just put arp rod bolts in there and you'll be fine
Old Jan 31, 2005 | 08:19 PM
notstock93's Avatar
Default Re: rod question?????? (mmuller)
I would balance the crank if I were you. Its cheap and Non-VTEC cranks are not zero-balanced from the factory like VTEC ones.
Ive personally seen LS rods/crank being rev'd to 10k (yes, thats right) for months on end. All he did was balance and use some ARP's.
That guy wasnt the brightest guy in the world, though.....im just saying ive seen it done.
Old Feb 1, 2005 | 08:18 AM
toooslow's Avatar
Default Re: rod question?????? (notstock93)
Does anybody know the correct part number
Do stock rods and aftermarket rods like eagle use the same bolt size?
I believe this is it but can somebody confirm (Part # ARP208-6001)
J.Berta
24
Feb 2, 2014 07:51 AM
Thundercat
Mar 28, 2008 10:52 PM
94WhtTeg
Oct 12, 2007 11:06 AM
EGcivicvtec
Jan 23, 2006 03:24 PM
ALL-MOTOR-BUBBLE
Aug 27, 2005 11:23 AM
