R spec Vtec controler Wiring help
Old Jan 31, 2005 | 04:05 PM
Garrett's Avatar
Default R spec Vtec controler Wiring help
I just bought a R Spec plug & play OBD-1 Vtec controler
And one of the wire is broke and I don't know where it goes
Someone know where to find informations How this vtec controler works and a wiring schematics of it
Thanks a lot guys
http://www.r-spec.com/manuals/out.html
Mine is VTC82X
Old Feb 13, 2005 | 04:18 AM
Garrett's Avatar
Default Re: R spec Vtec controler Wiring help (Garrett)
I still need your help
Old Feb 14, 2005 | 05:11 AM
mugenracer's Avatar
I'm getting an OBD1 R-spec controller any day now, post a close up picture of the wire thats broke and i will try and find out where it hooks up to for you once i get my own.
Old Feb 14, 2005 | 03:35 PM
Garrett's Avatar
Default Re: (mugenracer)
Supersize here : http://www.totaltuning.ca/albu...2.JPG
thanks alot for your help
Old Feb 17, 2005 | 09:36 AM
mugenracer's Avatar
Click here I have pointed out the blue wire location on your supersized pic.
Heres a Mitsubishi FTO site i found that has operation instructions for the R-spec controllers. The instructions are for the later OBD2 controller which has a few extra inputs over the OBD1 controller but general settings are the same. On the page linked below, at the bottom of the page where it lists the 5 extra functions, the OBD1 controller does not have these. (theyre for speed sensor signal, cylinder numbers and a few other adjustment things, nothing special.)
http://www.mitsubishi-fto.org/...x.htm
Old Feb 17, 2005 | 12:53 PM
Garrett's Avatar
thank you soooo much
93(Civic)EG6
Jul 29, 2007 12:56 PM
GSR-TRBO-DA
Jul 28, 2007 06:25 PM
downburst
Aug 24, 2006 06:28 PM
crxhfpower123
Nov 4, 2002 12:03 PM
