h22 swap problem?
is there any way i can use my map sensor from my 95 accord with the h22 cause i kno that the prelude one is on the firewall and mine is on the throttle body so what can i do??
you can try pluging the MAP into the vacuum hose that comes out of the TB for the prelude sensor. If it doesnt throw a CEL you should be good. I dont know how it will affect the readings being mounted that way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95accordh22a »</TD></TR><TR><TD CLASS="quote">so take mine off of the tb and plug it in is that what your saying?</TD></TR></TABLE>
Yes it does work.
Yes it does work.
