ZC high rev start
Old Jan 31, 2005 | 02:26 PM
SwissChEz82's Avatar
Default ZC high rev start
I finally got my ZC started and now everytime I start it it revs up to 4000 rpm before settling down 1500, I'm not sure why? Also I plugged in my pm7 to see if that would help and I get a code 11.
----->It doesn't idle at 4000 rpms it revs to 4000 than drops to 1500 and then runs at a normal 750 rpm rev when warm. On warm starts, I start it and it jumps to 4000 rpms for a second then it drops to a normal 750 rpm. So basically it runs normal except for the damn startup.
Modified by SwissChEz82 at 2:52 AM 2/3/2005
Modified by SwissChEz82 at 2:53 AM 2/3/2005
Old Jan 31, 2005 | 02:36 PM
Default Re: ZC high rev start (SwissChEz82)
Need quick help!!!
Old Jan 31, 2005 | 02:58 PM
crxgator's Avatar
check your cam timing, and code 11 means you got a shitty EDM ecu, that uses a CO pot sensor instead of an o2 sensor...
Old Jan 31, 2005 | 04:45 PM
Default Re: ZC high rev start (crxgator)
cam timing for what? how can i fix the ecu?
Old Jan 31, 2005 | 05:50 PM
crxgator's Avatar
to see if you set cam timing wrong...you cant fix the ecu, you have to use a different one...
Old Jan 31, 2005 | 06:41 PM
what the hell is a CO pot sensor, can I bypass it?
Old Jan 31, 2005 | 06:44 PM
crxgator's Avatar
no you cant, you have to get a different ecu...
Old Feb 1, 2005 | 06:21 PM
I originally thought it was my EACV and now I'm leaning more towards possibly having plugged the wrong harness into the plug. I replaced the EACV with the one from my Si engine and got rid if the idle surge but I still have the initial start, 4000 rpm rev.
Old Feb 1, 2005 | 06:42 PM
pendejon's Avatar
dude, just try a diff ecu, and it just might work right.
Old Feb 2, 2005 | 02:26 PM
Default Re: ZC high rev start (pendejon)
tried 2 different ECUs
Old Feb 2, 2005 | 04:48 PM
the wiring is right, does anyone have any other ideas as to why my car revs up to 4000 when i start it???
Old Feb 2, 2005 | 05:17 PM
crxgator's Avatar
did you check your timing like i said? cause that happened to me, the intake cam was off a tooth and it would idle at like 1500-2000...
Old Feb 2, 2005 | 05:21 PM
mr_valentino20032000's Avatar
i was just reading this on http://www.thezcr.com ...its the EACV they were saying. You have to take it off then adjust the idle screw then...well here is the link
http://www.binghamtonlife.com/...1.jpg
and if that isn't it here is the other
http://www.binghamtonlife.com/...7.jpg
Old Feb 2, 2005 | 05:24 PM
It doesn't idle it revs to 4000 than drops to 1500 and then runs at normal rev (750)when warm.
Old Feb 2, 2005 | 05:26 PM
oh ok, sorry thought i could help
Good luck and you might want to check out that ZC site though
Old Feb 2, 2005 | 05:30 PM
Default Re: ZC high rev start (mr_valentino20032000)
I already replaced the EACV and got rid of one problem but still have the startup problem. Thanks anyway.
Old Feb 3, 2005 | 02:51 PM
Could this be my problem???
Old Feb 4, 2005 | 05:04 PM
That did it, I took the one off my Si engine put it on the ZC and it turned over just fine. Thanks for the help.
89brokendownEF
Apr 12, 2016 09:14 AM
dohcef8si
18
Jun 7, 2005 10:01 PM
virginia_dude
Mar 11, 2002 11:47 AM
ern
Jan 17, 2002 07:40 AM
