Wheel size
Old Jan 31, 2005 | 01:27 PM
da'ee's Avatar
Default Wheel size
Would going with a 15x7 or 16x7in wheel be better for track use?
Old Jan 31, 2005 | 01:28 PM
Bbasso's Avatar
Default Re: Wheel size (answer3)
question is can you afford the 16 inch tires
Most people here use 15x7 for track use.
Old Jan 31, 2005 | 01:31 PM
da'ee's Avatar
Default Re: Wheel size (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">question is can you afford the 16 inch tires
Most people here use 15x7 for track use.</TD></TR></TABLE>
I know the price is an issue, but does the 16 in wheel/tire combo make a better track size than the 15?
Old Jan 31, 2005 | 01:33 PM
pitargue's Avatar
Not to mention that R compound tires choices in the 16" tire sizes is less than the 15" size.
Old Jan 31, 2005 | 01:35 PM
Flux's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by answer3 &raquo;</TD></TR><TR><TD CLASS="quote">I know the price is an issue, but does the 16 in wheel/tire combo make a better track size than the 15?</TD></TR></TABLE>
Unless you have brakes that need a larger wheel there is absolutely no reason to go to a 16" wheel in my opinion. The 15x7 will get you all the grip you need and will be loads lighter (which is a big deal).
Modified by Flux at 4:45 PM 1/31/2005
Old Jan 31, 2005 | 01:49 PM
Chris F's Avatar
Default Re: Wheel size (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">Unless you have brakes that need a larger wheel there is absolutely no reason to go to a 16" wheel in my opinion. The 15x7 will get you all the grip you need and will be loads lighter (which is a big deal).
I couldn't have posted it any better myself. If the 15x7's will fit, use them, because they will usually be lighter (faster) and cheaper.
-Chris
Old Jan 31, 2005 | 01:52 PM
uNF$@#!'s Avatar
Modified by Flux at 4:45 PM 1/31/2005</TD></TR></TABLE>
.... unless...you want to get 16x7 because then when you fly by someone you can brag about rolling them in heavy *** wheels.
Old Jan 31, 2005 | 04:11 PM
da'ee's Avatar
Default Re: Wheel size (255.255.255.255)
thanks for informative replies, looks like ill be going with a 15x7 wheel, I dont plan on running 12-15in brembo rotors anytime soon.
Old Jan 31, 2005 | 06:33 PM
Dropspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by answer3 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for informative replies, looks like ill be going with a 15x7 wheel, I dont plan on running 12-15in brembo rotors anytime soon.</TD></TR></TABLE>
I fit an 11.75" rotor and Wilwood caliper under a 15" wheel.
mattj
Old Feb 1, 2005 | 04:20 AM
da'ee's Avatar
Default Re: Wheel size (Dropspeed)
what about a 15x6.5, or is that too small for the 205 tires?
Old Feb 1, 2005 | 05:29 AM
Flux's Avatar
A 205 tire, especially the Falken Azenis due to its width, will feel (and perform) much better on a 7" wheel. It is about the angle of the sidewall on the wheel when installed.
Old Feb 1, 2005 | 07:44 AM
00R101's Avatar
15x7 is better than 16x7 for a Type R. Why?
1) Lower cost for same quality
2) Lower overall weight
3) Lower rotational inertia
4) Easier fit
5) For a given tire width and aspect ratio a 15" will result in a lower ride height than a 16"
regards,
alan
Old Feb 1, 2005 | 07:45 AM
00R101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by answer3 &raquo;</TD></TR><TR><TD CLASS="quote">what about a 15x6.5, or is that too small for the 205 tires?</TD></TR></TABLE>
You can fit a 225 on a 6" rim so a 6.5" rim will fit a 205 no problem
regards,
alan
Old Feb 1, 2005 | 09:54 AM
da'ee's Avatar
Default Re: Wheel size (00R101)
So what width would be the best for a 15in wheel? I thought 205 tires dont exactly fit perfectly on a 6.5in wheel?
Old Feb 1, 2005 | 10:06 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by answer3 &raquo;</TD></TR><TR><TD CLASS="quote">So what width would be the best for a 15in wheel? I thought 205 tires dont exactly fit perfectly on a 6.5in wheel? </TD></TR></TABLE>
Most people refer to the 205/50/15 Azenis not fitting properly on the stock 6" wide wheels. And they are correct, since the above tires run wider than average 205/50 marketed tires.
They do fit however. They just don't provide the same crisp turn-in that stock sized Re010's offer on stock wheels.
A better option for the Azenis would be 6 1/2" wide wheels or better yet 7".
But there are other 205/50/15 tires that fit the stock wheels closer/better.
Old Feb 1, 2005 | 02:12 PM
da'ee's Avatar
Default Re: Wheel size (1GreyTeg)
whats the optimal size for 205 size tire?
Old Feb 1, 2005 | 03:56 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">A better option for the Azenis would be 6 1/2" wide wheels or better yet 7".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by answer3 &raquo;</TD></TR><TR><TD CLASS="quote">whats the optimal size for 205 size tire?</TD></TR></TABLE>
Depends on the tire. 7" is a good size for the Azenis, as posted.
sonny0330
Nov 16, 2007 09:40 AM
DA9 panda A1
Oct 2, 2007 01:06 PM
hypnoticf23
Sep 4, 2006 01:03 PM
95dc2
13
Mar 8, 2006 08:31 AM
honda_coupe
Dec 22, 2005 07:12 PM
