Custom ECU tuners?
Old Jan 31, 2005 | 01:01 PM
Hyaboosta's Avatar
Default Custom ECU tuners?
does anyone know of any companys that do custom reflashes or tuning to stock ecu's? I know inline4 does and I emailed them. I wanted to have my rev limit removed,govenor removed and fuel curve changed a bit. Problem is I have an o2 civic ex and the only kind of ecu control we have for turbo is an AFC hack or emenage. I have an emenage. anyone know anyplace?
Old Feb 1, 2005 | 08:57 AM
Hyaboosta's Avatar
Default Re: Custom ECU tuners? (Hyaboosta)
bump for some info
Old Feb 1, 2005 | 09:56 AM
dwnthehatch's Avatar
http://www.ff-squad.com/ecu/
or PM k@man
Old Feb 1, 2005 | 12:53 PM
HODATCH1320's Avatar
Default Re: Custom ECU tuners? (dwnthehatch)
DO-IT DYNO PERFORMANCE CENTER 562-424-6162 ask for bubba
Old Feb 1, 2005 | 03:32 PM
Hyaboosta's Avatar
Default Re: Custom ECU tuners? (HODATCH1320)
I need someone that can remove the rev and speed gov. on an OBD-2 ecu from an 02 honda civic ex
Old Feb 2, 2005 | 08:35 AM
civic-4-ges's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hyaboosta &raquo;</TD></TR><TR><TD CLASS="quote">I need someone that can remove the rev and speed gov. on an OBD-2 ecu from an 02 honda civic ex</TD></TR></TABLE>
OBD2B=Un-chippable
Good Luck
It would be easier to convert to OBD1
Old Feb 2, 2005 | 09:22 PM
vtecmissle's Avatar
ericks racing or get can do it
Old Feb 3, 2005 | 12:02 AM
Equilibrium's Avatar
* B A N N E D *
If you're looking for something you can have a little fun with and not worry about emissions, you should get an OBD2-OBD1 conversion harness, and buy a chipped P28, P29, or P30 ecu, or chip it yourself. Make sure it's "slotted", so you can change the program as your upgrades progress. You're looking at about 250 dollars on Ebay.
Good Luck!
Old Feb 3, 2005 | 02:01 AM
Default Re: Custom ECU tuners? (vtecmissle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecmissle &raquo;</TD></TR><TR><TD CLASS="quote">ericks racing or get can do it</TD></TR></TABLE>
You sure about that??
Again...OBD2B=Un-Chippable
Old Feb 3, 2005 | 04:55 AM
Hyaboosta's Avatar
Default Re: Custom ECU tuners? (civic-4-ges)
obd2 to 1 conversion wont work my car doesn't have a distributor it has coil on plug ignition.
silentdaredevil2
Jan 7, 2007 06:08 AM
i-VTEC_do_you
14
Jan 2, 2007 11:48 AM
krucked_club
15
May 19, 2003 09:15 AM
lsvtec101
Jan 1, 2003 06:39 AM
ringgold
Jul 17, 2001 04:23 AM
