Skunk2 ECU trouble
Old Jan 31, 2005 | 11:56 AM
SOHCex20's Avatar
Default Skunk2 ECU trouble
Does anyone have any answers to their p28 skunk2 rich running condion, and fluctuating idle?? On my 99 EX I messed with the Ignition timing and idle screw both havent helped much. I plugged my stock ecu back in to see if there was a possible vac. leak, but with the stock ecu in it runs as smooth as possible. So far there has been no progress. Is the spoon p28 any better, worse, or roughly the same in performance?? Havent looked into that very much. Any help would be great. Thanks
Old Jan 31, 2005 | 12:31 PM
ninjastance_batmang's Avatar
Default Re: Skunk2 ECU trouble (SOHCex20)
i have a p28 with the skunk2 program as well.
runs stupid rich, reeks inside the cab, the idle is weird. when i first start the car in the morning, if i dont give it gas, the car will die. i have to rev it a bit for it not to die.
my guess for it dying, is the ecu is dumping way to much fuel, and it is... cause my gas mileage is horrible.
ive played with the idle, didnt help much.
Old Jan 31, 2005 | 12:35 PM
eK9aT10pSi's Avatar
Default Re: Skunk2 ECU trouble (batmang)
get a afc and fine tune the fuel. wideband
Old Jan 31, 2005 | 12:37 PM
my ecu is setup for neptune and will be tuned within the next couple weeks, hopefully the a/f setup will be fixed.
Old Feb 1, 2005 | 06:32 AM
SOHCex20's Avatar
Default Re: (batmang)
I am starting to invest in a vafc as well to help with the a/f mixture. Hopefully that will steady out my idle and stop dumping all the fuel in the car. Yea gas mileage has dropped a rediculous amount as well. Thanks for the info.
Old Feb 1, 2005 | 07:40 AM
eK9aT10pSi's Avatar
Default Re: (SOHCex20)
use the safc, much easier to adjust with. and if you dont plan on playing with the vtec engagement.
Old Feb 1, 2005 | 11:47 AM
SOHCex20's Avatar
Default Re: (eK9aT10pSi)
do those run cheaper than the vafc?? I'm not really worried about changing my vtec around either so thanks for the info on that.
Old Feb 1, 2005 | 02:11 PM
steve00si's Avatar
i am pretty sure that they are around the same price. around $250 new, someone correct me if i am wrong
SOHCex20
Jan 17, 2005 02:46 PM
D-Rob
Oct 27, 2004 09:24 AM
bananacruzier
Mar 22, 2002 04:34 AM
