JDM itr pistons stick out of the hole?!?!?!?
Old Jan 31, 2005 | 11:30 AM
importboi22's Avatar
Default JDM itr pistons stick out of the hole?!?!?!?
well everything just got screwed up i just installed my jdm itr pistons in my b16 block with b17 crank and rods, the pistons stick about 10 thou OUT of the block!!!
i was just wondering is it normal for jdm itr pistons to stick out of the block? what is the compression height on them if anyone knows off the top of there head! thanks for your time!
Old Jan 31, 2005 | 11:47 AM
Default Re: JDM itr pistons stick out of the hole?!?!?!? (importboi22)
i just figured my compression out
with milled 15 thou
flat valves
pistons out of the hole 10 thou
i have 12.5:1 !!!!! GAY!!!! i only have 91 availble T_T
Old Jan 31, 2005 | 11:59 AM
projectegr's Avatar
this sounds about right but are you sure you got p73 pistons and not pct?
Old Jan 31, 2005 | 12:02 PM
Sliced Beard's Avatar
Default Re: JDM itr pistons stick out of the hole?!?!?!? (projectegr)
to my knowledge the PCT's are the only pistons that stick out of the hole on B16/17 blocks
the P73-oo and P73-Ao should sit flush with the deck.
Old Jan 31, 2005 | 12:03 PM
Default Re: JDM itr pistons stick out of the hole?!?!?!? (DirtySol)
nope they are sticking out i need to get a camera i thought they sat flush TOO
Old Jan 31, 2005 | 02:34 PM
bump
Old Jan 31, 2005 | 03:08 PM
non-VTEC's Avatar
did you have the surface of the deck milled?
Old Jan 31, 2005 | 09:08 PM
Default Re: JDM itr pistons stick out of the hole?!?!?!? (non-VTEC)
nope never milled
Old Jan 31, 2005 | 09:40 PM
onepoint6i's Avatar
Is B17 block and B16 block same height?
Old Jan 31, 2005 | 10:28 PM
Default Re: JDM itr pistons stick out of the hole?!?!?!? (1.6i)
yes
c5stunna
Sep 29, 2007 01:13 AM
SOLORIO
12
Feb 28, 2007 03:17 PM
mrDFWmechanic
Aug 1, 2005 10:32 PM
markaria
Oct 10, 2004 06:23 PM
robhamaliuk
Jan 24, 2003 10:17 AM
