Anyone on here running a JDM B16a tranny with GSR motor.
Old Jan 31, 2005 | 09:48 AM
92-LS-Civic's Avatar
Default Anyone on here running a JDM B16a tranny with GSR motor.
I was just wondering how it was on the highway and how it is on the street. Is it good/bad. thanks
Old Jan 31, 2005 | 10:58 AM
B_CRUZ!'s Avatar
Default Re: Anyone on here running a JDM B16a tranny with GSR motor. (zdowell17)
perfect gear ratio IMO same rear ratio as a usdm ITR tranny but without the LSD.
Old Jan 31, 2005 | 11:00 AM
Slain's Avatar
lol you can use 5th gear as a passing gear still on the freeway.
Old Jan 31, 2005 | 11:12 AM
LSvtec03's Avatar
Default Re: (Slain)
i have it on my lsvtec. close enough?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">lol you can use 5th gear as a passing gear still on the freeway. </TD></TR></TABLE>
lol. this is true. for the street, the b16 is perfect. as for highway, you're at 3750 @65 mph, 4000 @70, and hitting vtec by 80. then again, this is on my ys1 which has the shortest of all the b series gears. all the other b16s (excl. 99-00 si) will be a little more bearable in 5th gear on the highway.
specnically speaking b-series gear ratios
speed/rpm calculator
Old Jan 31, 2005 | 03:31 PM
blairgsr's Avatar
Default Re: (LSvtec03)
b16 trannies are the ****, it makes a big difference on a stock gsr motor, pulls hard 1st-2nd and yes 5th is like a passing gear, but bareable...
Old Jan 31, 2005 | 08:01 PM
k, i am going to hope that the tranny will work with that clutch. one more question that came to mind. will my axles work with that tranny?
Old Jan 31, 2005 | 08:21 PM
4DooRGiSzer's Avatar
i just bought a JDM B16 tranny, i cant wait for it to be put on my GSR!! it is probably going to be the best upgrade ever as of now. Go for it all the way!!
Old Jan 31, 2005 | 09:43 PM
SYTFU Tommy.'s Avatar
Default Re: Anyone on here running a JDM B16a tranny with GSR motor. (4DooRGiSzer)
the clutch and axles should work as long as they are from a b series if i am correct
Old Jan 31, 2005 | 11:42 PM
eddiedeader's Avatar
Default Re: Anyone on here running a JDM B16a tranny with GSR motor. (tngay)
I got a b16 J1 with a kaaz LSD connected to my b18c1. Its a nice combination but be prepared to cruise on the freeway at 5k, personally i like the fact that i can pass in 5th and even though i got a greddy sp and its still loud as F**K.
Old Feb 1, 2005 | 10:21 AM
Default Re: Anyone on here running a JDM B16a tranny with GSR motor. (eddiedeader)
what speed are you at when the tach is at 5K. 75? anyone else with personal experience that has went from a GSR to a b16. I just need to make sure before i buy this 750 dollar JDM b16.
Old Feb 1, 2005 | 12:27 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zdowell17 &raquo;</TD></TR><TR><TD CLASS="quote">what speed are you at when the tach is at 5K. 75? anyone else with personal experience that has went from a GSR to a b16. I just need to make sure before i buy this 750 dollar JDM b16.</TD></TR></TABLE>
4500 is 80 on a ys1. 5000 is more like 86. check out those sites i posted and all will be answered.
jdm ys1 speed per rpm in each gear
jdmkid8383
Jan 3, 2008 06:50 PM
posHonda
Oct 18, 2007 10:27 AM
genius
Nov 12, 2003 06:00 PM
heel_touge
Mar 20, 2003 11:39 AM
