Valve adjustment after removing head??
Old Jan 14, 2002 | 05:21 PM
B19CivicHB's Avatar
Default Valve adjustment after removing head??
Im about to take the head off my JDM GSR (1995) and its says in the Helms manual to adjust the valves after everything is back in... do i REALLY have to do that??? Its such a pain to adjust all the valves... please tell me i dont have to do that...
Old Jan 14, 2002 | 06:20 PM
fixhondas's Avatar
Default Re: Valve adjustment after removing head?? (B18CivicHB)
If you take the cam saddles off then you must adjust the valves. Be sure to turn the crank over a few times after reassembly to "seat" the cam and then do the adjustment. If you don't remove the saddles/cams then you don't have to adjust the valves.
Old Jan 14, 2002 | 06:57 PM
EPGONZALEZ's Avatar
Default Re: Valve adjustment after removing head?? (fixhondas)
pain in th ***? do you have the special tool? it makes the a cake walk..
Old Jan 15, 2002 | 04:15 PM
B_CRUZ!'s Avatar
how can you remove the head without removing the cams?
Old Jan 15, 2002 | 05:44 PM
fixhondas's Avatar
Default Re: Valve adjustment after removing head?? (initial_B)
depends on which head you are talking about- most sohc you can leave it in- most dohc you can't (if not all)
S13 slide
Mar 24, 2006 02:25 PM
ZCcivicBOI
Mar 9, 2006 10:52 AM
menappi
Jul 28, 2005 01:45 AM
quicksol95
Mar 14, 2005 05:47 PM
gsrjay
Sep 2, 2004 05:05 AM
