clutch has two engagement points??
Old Jan 31, 2005 | 09:11 AM
type Gendy's Avatar
Default clutch has two engagement points??
I dont know if any of you guys with cable trannies have experienced this before, but i have in a few different efs. Sometimes while driving, the clutch (dis?)engagement point changes.
In my hatch, it usually catches were it is suppose to near the top, but sometimes it grabs way down low like an inch off the floor. So sometimes i stall or i can save it. So now i am starting to ride the clutch in case it does come in way early.
Anybody know why this is happening? or ever have it happen to them?
Old Jan 31, 2005 | 09:24 AM
manson's Avatar
Default Re: clutch has two engagement points?? (Evil Sick hatcheM)
i thought i was the only one....
It happens to me every once and a while... i think my cable is binding every so often causing the pedal enguagment to change.
it doesn't bother me enough to attempt to fix it yet, but when i do the first thing to get changed will be the cable.
Old Jan 31, 2005 | 11:05 AM
Kwicko's Avatar
Default Re: clutch has two engagement points?? (manson)
My '91 DX was doing that for a while before I pulled the old drivetrain out and replaced it with better stuff. When I pulled the transmission off the engine, a couple of the clutch disk springs fell out on the floor. Seems they like to work their way loose and mess with the engagement a bit. I had an Integra a few years back that actually lost its clutch due to one of those damn springs wandering... it got lodged between the clutch disk and the flywheel surface, and the clutch became utterly useless. I got it home with rolling stops and rev-matching the shifts.
If your clutch engagement is changing, start preparing yourself for the time and expense of a clutch replacement.
Mike
Old Jan 31, 2005 | 11:12 AM
type Gendy's Avatar
Default Re: clutch has two engagement points?? (Kwicko)
My clutch looked fine, just had the motor/tranny out a month ago.
Old Feb 1, 2005 | 01:45 PM
type Gendy's Avatar
Old Feb 1, 2005 | 02:34 PM
user 98292739's Avatar
yea mine went from all the way up top to all the way at th bottom one day....but now i think its messing with my rpms dropping very slowly...might be what you asaid spring or somethign loose...but its pissin gme offf
Old Feb 1, 2005 | 08:20 PM
type Gendy's Avatar
Default Re: (LoCoReX)
I guess alota ppl are telling me they've experienced this before.
Old Feb 4, 2005 | 03:22 PM
type Gendy's Avatar
Default Re: (sick hatchem)
wtf
Old Feb 7, 2005 | 05:28 PM
type Gendy's Avatar
IT MADE me soo mad yesterday i almost slammed the pedal thru the firewall
Old Feb 7, 2005 | 05:31 PM
Turbo_Mike's Avatar
That happens from time to time on my car(s) too, its really a pita cause if it happens at a light somtimes i just stall it out not expecting it
Old Feb 7, 2005 | 05:40 PM
tpr's Avatar
tpr
Default Re: clutch has two engagement points?? (sick hatchem)
This two point engagement may be caused by the release bearing piviot shaft binding. Few people check this easy to remove, clean and relubricate shaft. With the transmission out, remove the bolt holding the release bearing frok to the shaft. Then pull the shaft out of the side of the bell housing. Clean off the old dried grease then lub it up with a caliper grease (high Temp). Reinstall the shaft in reverse order. It should then move freely and the clutch action will return to the smoothly designed Honda 5 SPD it was born to be.
Old Feb 7, 2005 | 05:42 PM
.Noah Fecks's Avatar
Default Re: clutch has two engagement points?? (tpr)
i love the way you get on ht to continue to bitch about it, but dont take a few minutes to figure out the problem. maybe your clutch line is loose.
Old Feb 7, 2005 | 05:45 PM
Reason's Avatar
Default Re: clutch has two engagement points?? (Noah *****)
i ahd this problem on all of my crx's. i just changed the cable everytime it happen. i think has something to do with the cable strectching. just replace it with a new one and your problem should be solved.
Old Feb 7, 2005 | 05:48 PM
type Gendy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noah ***** &raquo;</TD></TR><TR><TD CLASS="quote">i love the way you get on ht to continue to bitch about it, but dont take a few minutes to figure out the problem. maybe your clutch line is loose.</TD></TR></TABLE>
WTF are you talking about? I've taken more than a few minutes to look at it as much as i can, short of pulling the tranny. Thanks for making a useless post and adding no value to this thread asshat Wheres the clutch line? Maybe i'll go try to check that if my dad can help me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reason &raquo;</TD></TR><TR><TD CLASS="quote">i ahd this problem on all of my crx's. i just changed the cable everytime it happen. i think has something to do with the cable strectching. just replace it with a new one and your problem should be solved. </TD></TR></TABLE>
New cable huh? Maybe i'll try that.
exz0n-.-
Jan 6, 2009 06:53 PM
Pooby88
Mar 1, 2008 05:55 AM
See Are X
Apr 25, 2002 05:04 PM
