won't start......d16z6
Old Jan 31, 2005 | 08:55 AM
spacin's Avatar
Default wouldn't start then it ......d16z6
why ?
ok last night she ran fine, no troubles ever. I go to start it this morning and alls it does is cranks, never turning over, not even a glimer of hope. has plenty of gas and the fuel rail is getting gas. plugs look ok.
what or how can i tell if the distributor is sparking or if i need a new one.
where do i look for more things on why it wont start , where do i go from here?
any help will be greatly apprecated..... thanks
Modified by spacin at 12:18 PM 1/31/2005
Modified by spacin at 1:04 PM 1/31/2005
Old Jan 31, 2005 | 11:59 AM
spacin's Avatar
Default Re: won't start......d16z6 (spacin)
weird i just went outside to try again and its running now...
it didnt want to start at first but i gave it a little gas and it fired right up ...lots of smoke out the back at first but seems ok?
wtf? any ideas? dizzy going bad? ignitor going bad? time for a new cap and rotor?and some new plugs... pretty sure neither has been replaced in awhile.....
Old Jan 31, 2005 | 12:32 PM
EK45VTi's Avatar
Try to let th pump prime few times before you crank the car...
I always do it when it is cold...
I usualy let the pump prime 3 times before I start the car...
Old Jan 31, 2005 | 12:34 PM
EK45VTi's Avatar
Default Re: won't start......d16z6 (KKVTi)
And yes, I forgot to tell you...
DO NOT APPLY GAS when starting...
Just prime 3-4 times and start the car without pushing the gas pedal... it should start without problem...
Old Jan 31, 2005 | 12:36 PM
technine's Avatar
Sounds like igniter to me since they don't give too much of a sign when they go out plus you said you had a lot of smoke which probably means there was a lot of fuel in the chambers=fuel is working, but no spark.
Next time take a plug out, keep it hooked up to the wire and put it close to metal and start it, if you see a spark, you have spark, if you don't, no spark= your problem. HTH
Old Jan 31, 2005 | 07:54 PM
spacin's Avatar
Default Re: won't start......d16z6 (technine)
yeah thats what i thought also
just seem weird that it would start at all
still running fine atm, i think i'll replace everything dizzy wires plugs just in case
Old Feb 1, 2005 | 10:38 AM
spacin's Avatar
wtf same thing today
what the hell
i've never had trouble starting cold guess i'll do some more searching
any one got any ideas??
Old Feb 1, 2005 | 01:11 PM
vtecn8ive's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by technine &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like igniter to me since they don't give too much of a sign when they go out plus you said you had a lot of smoke which probably means there was a lot of fuel in the chambers=fuel is working, but no spark.
Next time take a plug out, keep it hooked up to the wire and put it close to metal and start it, if you see a spark, you have spark, if you don't, no spark= your problem. HTH</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KKVTi &raquo;</TD></TR><TR><TD CLASS="quote">And yes, I forgot to tell you...
Just prime 3-4 times and start the car without pushing the gas pedal... it should start without problem...</TD></TR></TABLE>
Take their advice. Did you check for spark?
Old Feb 2, 2005 | 06:39 AM
spacin's Avatar
Default Re: won't start......d16z6 (vtecn8ive)
it starts speraticly, started up fine as day this morning, so i asume its getting spark
seems strange .... i'm gonna pull out a plug today and see if it sparking strong or iif its hella dirty......
Old Feb 2, 2005 | 12:50 PM
vtecn8ive's Avatar
When its not starting try it.
misfits_skater
Dec 5, 2007 05:08 AM
YAH YAH
Jun 30, 2007 02:13 PM
z crx z vtec z
Jun 13, 2007 03:19 PM
xkagax
13
Feb 22, 2006 05:47 AM
DA6_toojy
Oct 12, 2005 06:30 PM
