HID experts. HELP!! How do I wire these to my EG?
Im having trouble figuring out what do to with these.
Why are there 4 wires out of the bulb? high/low beam??
Anyways what is with all the wiring and fuses/relay? AHH help! im confused.. i dont know electrical stuff.
Help would greatly be appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Not exactly what you were asking, but this should help
https://honda-tech.com/zerothread?id=1118436</TD></TR></TABLE>
Looks exactly like what I have.
but now how do i wire it in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btcca4 »</TD></TR><TR><TD CLASS="quote">
but now how do i wire it in?</TD></TR></TABLE>
I thought that writeup told you how to install it. I didn't even bother to read it thorougly. Sorry.
you have a little wedge bulb on the actual hid bulb right?? IF so, then those two yellow wires are for that wedge bulb. those are suppose to act like a day time running light more so a city driving light. if you dont want to use them you can just un-screw the wedge bulb and pull the wires off.
As for the HID portion, its as simple as a p0wer and ground coming from your ballasts which looks like its plug and play
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsisi »</TD></TR><TR><TD CLASS="quote">you have a little wedge bulb on the actual hid bulb right?? IF so, then those two yellow wires are for that wedge bulb. those are suppose to act like a day time running light more so a city driving light. if you dont want to use them you can just un-screw the wedge bulb and pull the wires off.
Yes I do understand that but what are those 2 wires?? white and black??
Where do they go??
Where do they go??
btcca4, well you did ask this:
"Why are there 4 wires out of the bulb? high/low beam??"
so i answered that question.
Now, the black and white wire are to plug into your stock plug (the plug that would normally plug onto the back of your old H4 lightbulb), it is using your stock wiring as the "on" signal to put power from the battery to the ballasts.
btcca4
Audio / Security / Video
Jan 31, 2005 12:22 PM
yesbuy
Dec 27, 2003 08:09 AM
