Whats the symotoms of an bad ignition switch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">Sounds like the switch. To double check, test for voltage on the starter wire coming from the switch.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplin »</TD></TR><TR><TD CLASS="quote">Im trying to trouble shoot my car and i think its the switch. The only way i can start my car is if i "jump" my starter. </TD></TR></TABLE>The only way to REALLY know is by using a multi-meter. What you say could be the switch or it could be a disconnected wire from the switch to the starter. But flaky switches are pretty common.
what are you guys calling a ignition switch, the whole ignitino, or just the plastic switch at the end opposite of the key slot, thats the igntion switch, correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6hatch »</TD></TR><TR><TD CLASS="quote">just the plastic switch at the end opposite of the key slot</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6hatch »</TD></TR><TR><TD CLASS="quote">what are you guys calling a ignition switch, the whole ignitino, or just the plastic switch at the end opposite of the key slot, thats the igntion switch, correct?</TD></TR></TABLE>
the ignition switch consist of two parts, the mechanical and the electrical
is it shown in this picture here? Or can someone tell me where it would be?(http://www.acuraautomotiveparts.net) I am having the same problem. There is no Signal going to the starter when i turn on the iginition.
We've been talking about #23, but remember it could also be wiring from there to the starter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">The only way to REALLY know is by using a multi-meter...</TD></TR></TABLE>
imzjustplayin
Apr 17, 2008 09:08 AM
