will this oil filter kit work with ls blocks
Old Jan 31, 2005 | 12:40 AM
menkio's Avatar
Default will this oil filter kit work with ls blocks
summit.com item SUM-G4985, just look it up, single oil filter relocation kit. Wondering if the adapter that sandwhiches on the block won't fit are imports. Should it.. anyone have this.. ?
SUM-G4985
Old Jan 31, 2005 | 03:56 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: will this oil filter kit work with ls blocks (menkio)
it is probably based on a gm style filter, or ford. it says what fram filter to use, and the threads are probably domestic. if you get the golden eagle or the greddy sandwich plate, you probably could use the remote adapter with the fram filter it calls for. but as for bolting directly to your block, i dont think it will.
Adankid
Jan 1, 2009 03:12 PM
jesimmers
17
Mar 15, 2007 10:20 AM
ninety-five_DB
Jul 8, 2006 05:03 PM
Teg4e
Dec 18, 2003 08:46 PM
