Combo for ITR b-pipe use on EG?
Old Jan 14, 2002 | 04:37 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Combo for ITR b-pipe use on EG?
Ok, I was told this would work.. US ITR manifold, US ITR cat, US ITR b-pipe, -> stock EG axle-back (si)... Anyone agree?
Basically, I wanna use an ITR manifold and b pipe, with some stock cat and have it hook up to my GReddy SP axle-back (altho I do have the whole cat-back)... just tired of the noise from a header and 2.5" cat and tired of my car in general..
Anyhoo, TIA.
Old Jan 14, 2002 | 05:39 PM
EH3-R's Avatar
Default Re: Combo for ITR b-pipe use on EG? (SkyeC)
might fit since the 94+ integras have the smae wheelbase as eg hatches. btw do u have ne pictures of your sp exhaust??? thx
Old Jan 15, 2002 | 05:57 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
correct. when i first put my eg together, i used the stock itr manifold & b pipe, stock itr cat and it bolted up to my stock exhaust.
Old Jan 15, 2002 | 06:06 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Combo for ITR b-pipe use on EG? (rodney)
Bolts up. I've got the same set-up, only my exhaust is a Tanabe Racing Medallion for the 1992-1995 DX/Si hatch. You should be fine though.
Old Jan 15, 2002 | 06:16 AM
bgod's Avatar
Default Re: Combo for ITR b-pipe use on EG? (B18C5-EH2)
friend has this set-up. itr cat, itr b-pipe and 5aigen axle back exhaust.
bolts up perfectly. he was using the stock rear section before that.
Old Jan 15, 2002 | 06:47 AM
. o 69 o .'s Avatar
Default Re: Combo for ITR b-pipe use on EG? (bgod)
What about if a jdm ITR header was used? what extra pieces would be needed?
Old Jan 15, 2002 | 08:15 AM
duckman's Avatar
i just did mine (US itr header, US itr cat, US itr b-pipe, Si muffler) and the stock Si muffler does not fit correctly... the holes do not line up.. i had to use only one spring-loaded bolt... and i don't have any exhaust leaks...
duckman
Old Jan 15, 2002 | 09:18 AM
Kalokohan's Avatar
New User
Does this work for all years of USDM ITR's? I heard that the 97-98 ITR manifolds were a different length than the other years? Yay or Nay?
Old Jan 15, 2002 | 09:23 AM
Rodney's Avatar
Default Re: Combo for ITR b-pipe use on EG? (Guardson3r3)
yay. 97,98,00, and 01 will work. they are the same exact pieces.
red_sir
Nov 8, 2002 09:20 AM
SkyeC
Aug 23, 2002 03:54 PM
keys
May 1, 2002 10:05 AM
Frito1
Feb 20, 2002 01:22 PM
ajchen
Nov 30, 2001 07:42 AM
