obd questions
ok here is the deal i have an obd2a car but i am running an obd1 ecu with a convertion kit. now what i wanted to know is can i run an obd1 gsr dizzy on my b16 being that i am running my obd1 p28 will that work or is it a done deal need an obd2a dizzy no matter what i run?
Modified by civiclxb16 at 2:20 PM 1/31/2005
the dizzy plugs are different. you'll need to re-wire it to make it work. i don't think there's a write up on it. you could just change the dizzy to the correct obd plug and be done with it.
6th post down, you'd have to do the opposite (meaning you'd need to get the correct 2nd plug and wire the 2 wires to it): https://honda-tech.com/zerothread?id=550976
Mr_Moos
15
Oct 19, 2009 10:36 PM
NACvicSi
10
Feb 18, 2006 06:41 PM
Freeltec
Jan 7, 2006 12:31 AM
