HELP!!!!car is throwing iac check light after swapping an ex intake manifold on my dx
Old Jan 30, 2005 | 08:31 PM
KiNG $h!t's Avatar
Default HELP!!!!car is throwing iac check light after swapping an ex intake manifold on my dx
my car is throwing iac check light after swapping an ex intake manifold on my dx, but my original harness has 3 wires for its idle control valve and the ex manifold takes only 2. i rewired it using the 2 wires on my original harness that were the same color as the wires that would be on an ex 2 wire harness and left the extra wire off, but the car is still idleing real bad. it revs up and down real fast. how can i fix it? does the idle control valve just need to be cleaned?
Old Jan 30, 2005 | 08:57 PM
ek9poorR's Avatar
Default Re: HELP!!!!car is throwing iac check light after swapping an ex intake manifold on my dx (this guy
are you still using the dx harness?? cuz if you do, it wont work get the ex ecu.
Old Jan 30, 2005 | 09:03 PM
polymath's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9poorR &raquo;</TD></TR><TR><TD CLASS="quote">are you still using the dx ecu?? cuz if you do, it wont work get the ex ecu.</TD></TR></TABLE>
Old Jan 30, 2005 | 09:37 PM
Rusty Shackleferd's Avatar
you need to switch some wires on the ecu plug.
http://www.hondaswap.com/forum...48020
Slick2126
Apr 2, 2006 05:03 AM
DteKMotorwerkz
Jan 30, 2004 07:05 PM
Drew96EJ
Sep 27, 2003 09:58 PM
Drew96EJ
Sep 23, 2003 01:49 PM
