Whats happening?
I wind out first gear no problem and then shift to second and wind that gear out and then when I shift to third and immediately floor it, it hesitates for a second or two and then picks up speed again (I have a soft spot where I don't accelerate). My rpms don't seem to go way up so I don't think my clutch is slipping. What is this?
Brand new clutch( Grip Force stage 1)
Brand new flywheel(11LB FLYWHEEL FROM JDM CONCEPTS)
Could it be that I didn't take it easy on my new flywheel(break it in) for a while and it has hot spots that could be causing the bogging or soft spot in acceleration.
Could it be I'm not getting enough fuel where I need it most and this is causing the stop in acceleration?
Its a 94 jdm gsr with lightweight crank pulley, short air intake, jdm type-r header, 2.25 exhaust, 11 lb flywheel, stage 1 clutch kit, in a 1998 civic.
Thanks
98civic94gsr
Modified by 98civic94gsr at 9:04 AM 1/31/2005
Modified by 98civic94gsr at 9:17 AM 1/31/2005
Thanks
98civic94gsr
random bogging, this happens to lots of people and it could be a xillion different things.
start wityh the cheap stuff, basics like fuel filter, spark plugs, distributor cap/rotor, o2 sensor, to name some possibilities.
Alright I'll check all of that. Just bought a fuel filter today. Gonna put that in tommorow and the only other thing that you listed that isn't new is the o2 sensor.
Thanks
Thanks
eg6 type-R
Apr 9, 2012 06:19 AM
shadowfox375
Honda Civic (2006 - 2015)
30
Apr 15, 2009 05:57 PM
SandstormGT
11
Mar 27, 2006 10:30 AM
